I was running octopi great when I got an error about my camera not taking snapshots correctly. This happens occasionally, and a reboot fixes it, so I rebooted and now the octopi ui is not showing up.
Tried to ssh into octopi and run commands as specified in the error screen when it wouldn't connect ( ps -ef | grep -i octoprint | grep -i python yielded no output)
https://hastebin.com/tewecicati.sql
I honestly don't know, and because I can't boot I can't check, but i believe its all up to date as far as the octopi unit itself...
Hello @benjaminb!
In the end, the server is running:
2020-01-27 06:25:27,722 - octoprint.server.heartbeat - INFO - Server heartbeat <3
but this:
2020-01-26 20:27:47,114 - octoprint.timelapse - ERROR - Could not capture image /home/pi/.octoprint/timelapse/tmp/Large_Bottom_Rounded_HBWood_Charger_20200126173548-10.jpg from http://127.0.0.1:8080/?action=snapshot
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/timelapse.py", line 614, in _perform_capture
f.flush()
IOError: [Errno 28] No space left on device
You may overfilled the SD card with timelapses...
Ahh makes sense now, I was getting the error but it just seemed like the camera couldn’t write the files to the card for some reason...is there a way, via ssh, to clear out the extra files?
When you login via SSH, you must go to the timelapse storage folder and use the linux command rm.
For I don't use tamelapses, I can't tell you where it can be, sorry.
