Octoprint will work fine and flawlessly for several hours or even days, but then it'll just stopp responding, pause the print, and leave the hot end running. The way I know it crashes is that the UI stops responding and says that its offline and will not come back (this normally happens when im not there or asleep so it can just be sitting and cooking the filament for hours).
I've been here before trying to fix this same issue and it seemed fixed and fine. I installed a new creality v4.2.7 board and reflashed the octopi from scratch and it was stable for a while until yesterday around time stamp 2021-01-29 13:53:20,812 and again around 2021-01-30 06:11:51,476 when the pi just.... stopped. I dont see any errors in the logs it just seems to decide to not be connected to anything and stop running.
Reflashed from 0.17 to latest 0.18, updated all plugins, performed:
sudo apt-get update --fix-missing
sudo apt-get upgrade
sudo reboot
enabled "wait for start on connect" in serial connection
yes
too random to tell. might wait an hour or 2 days. cant see anything in the logs
Complete Logs
octoprint (8).log (736.4 KB)
Version 0.18.0, running on Raspberry Pi 4 Model B Rev 1.4
Version 1.5.3
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/88.0.4324.96 Safari/537.36 Edg/88.0.705.53
connectivity.connection_check : 8.8.8.8:53
connectivity.connection_ok : true
connectivity.enabled : true
connectivity.online : true
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : true
env.hardware.cores : 4
env.hardware.freq : 1500
env.hardware.ram : 1771343872
env.os.bits : 32
env.os.id : linux
env.os.platform : linux
env.plugins.pi_support.model : Raspberry Pi 4 Model B Rev 1.4
env.plugins.pi_support.octopi_version : 0.18.0
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 20.3.3
env.python.version : 3.7.3
env.python.virtualenv : true
octoprint.safe_mode : false
octoprint.version : 1.5.3
printer.firmware : Marlin bugfix-2.0.x (Jan 29 2021
