Octopi starts in normal fashion. When I hit connect, it connects to MK3s+ ( i can tell by printer resets). I have older gcodes in file system and new ones. When I click any gcode nothing happens. Same is true of small icon for Load & Print. I can see the gcode image by clicking on icon. I have tried multiple times. I have tried the Serial Port and baudrate at Auto. they default back to /dev/ttyACM0 250000
Was working beautifully, till yesterday. Tried Safe mode,
Could you open the browser error console (F12 or ctrl-shift-i on Windows/Chrome/Edge) and see if there's any errors posted there when you try and start a print?
Thanks for the reply. I found the problem and now the printer is off and running. I do not want to open the the octopi while it is working.
The solution was the Baud rate. I tried 2 settings, Auto and the default 2xx,xxx ( i cant remember the number) but it is in my original question. I changed the baud rate to 115200 and as the Brits say Bob is your uncle, the problem is solved
