With OctoPi installed and running, the Pi doesn't see the printer (Ender 3).
I've tried switching through 4 different USB cords, 2 Pis (a 2B and 3B), and connecting to a different power source (and even tried switching the printer to a different power source). None of this has allowed me to connect to the printer.
Currently have OctoPrint 1.3.11 connected to an Ender 3 1.1.6 with stock firmware.
When the printer is powered on, octoprint doesn't see it at all (in the octoprint log, it never acknowledges a port is plugged in). When the printer is off, if I don't block the pin in the USB cord (so the printer 5V is powered by the Pi), octoprint does see the printer on /dev/ttyUSB0, but cannot connect.
Here's the OctoPrint log from the latest powered-from-USB run (after the two web links that keep giving me posting errors):
2019-05-14 20:16:30,420 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.102
2019-05-14 20:16:31,886 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.102
2019-05-14 20:16:32,043 - octoprint.server.util.flask - INFO - Passively logging in user dummy from ::ffff:192.168.1.102
2019-05-14 20:16:46,809 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-05-14 20:16:46,876 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-05-14 20:16:47,731 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect_port, payload: {'commerror_text': 'Failed to autodetect serial port, please set it manually.'}
2019-05-14 20:17:06,461 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-05-14 20:17:14,806 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-05-14 20:17:15,065 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Connection error, see Terminal tab"
2019-05-14 20:17:15,101 - octoprint.util.comm - ERROR - Unexpected error while connecting to serial port: AUTO IspError: ''Timeout'' @ comm.py:_openSerial:2611 (hook default)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2611, in _openSerial
serial_obj = factory(self, self._port, self._baudrate, settings().getFloat(["serial", "timeout", "connection"]))
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2579, in default
port = self._detect_port()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2560, in _detect_port
programmer.connect(p)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/avr_isp/stk500v2.py", line 34, in connect
self.sendMessage([1])
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/avr_isp/stk500v2.py", line 108, in sendMessage
return self.recvMessage()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/avr_isp/stk500v2.py", line 119, in recvMessage
raise ispBase.IspError("Timeout")
IspError: 'Timeout'
2019-05-14 20:17:15,997 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_connection, payload: {'commerror_text': 'Connection error, see Terminal tab'}
2019-05-14 20:17:23,275 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Connection error, see Terminal tab"
2019-05-14 20:17:23,303 - octoprint.util.comm - ERROR - Unexpected error while connecting to serial port: AUTO IspError: ''Timeout'' @ comm.py:_openSerial:2611 (hook default)
IspError: 'Timeout'
2019-05-14 20:17:24,001 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_connection, payload: {'commerror_text': 'Connection error, see Terminal tab'}
2019-05-14 20:17:59,772 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2019-05-14 20:17:59,788 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2019-05-14 20:18:33,193 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2019-05-14 20:23:09,174 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2019-05-14 20:23:09,184 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2019-05-14 20:23:42,592 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2019-05-14 20:28:36,589 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-14 20:29:14,209 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 930}
And without the USB power:
2019-05-14 20:38:39,361 - octoprint.server.preemptive_cache - INFO - ... done in 9.11s
2019-05-14 20:39:47,999 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.102
2019-05-14 20:39:49,450 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.102
2019-05-14 20:39:49,609 - octoprint.server.util.flask - INFO - Passively logging in user dummy from ::ffff:192.168.1.102
2019-05-14 20:41:51,650 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-05-14 20:41:51,702 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2019-05-14 20:41:52,635 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect_port, payload: {'commerror_text': 'Failed to autodetect serial port, please set it manually.'}
