Basic problem: Wireless network connection is lost by Pi and it never regains it. Connection via name or IP does not work.
Turned off wifi power save, both in /etc/rc.local (which is deprecated I hear) and cron job at reboot to turn off wlan0 power save.
When this wireless disconnect happens, I can access the pi only if I run an ethernet cable to it. Then, miraculously, both connections are active. However if the ethernet connection is removed, the wireless connection somehow deactivates. When ethernet is active, I can ping either IP address successfully. I can also ping via the hostname. When wired ethernet is removed, I cannot access the pi via the wireless IP, or the pi's hostname which is octorpi4.local
Ping when no wired ethernet, from laptop
% ping 192.168.40.210
PING 192.168.40.210 (192.168.40.210): 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
Request timeout for icmp_seq 2
^C
/etc/resolv.conf is not used by a mac. Below is the correct command for finding dns on a mac. *.119 is pihole, *.1 is the router.
% scutil --dns
DNS configuration (for scoped queries)
resolver #1
search domain[0] : lan
nameserver[0] : 192.168.40.119
nameserver[1] : 192.168.40.1
if_index : 15 (en0)
flags : Scoped, Request A records
reach : 0x00020002 (Reachable,Directly Reachable Address)
pi@octorpi4:~ $ cat /etc/resolv.conf
# Generated by resolvconf
domain lan
nameserver 192.168.40.1
pi@octorpi4:~ $ route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.40.1 0.0.0.0 UG 202 0 0 eth0
default 192.168.40.1 0.0.0.0 UG 303 0 0 wlan0
192.168.40.0 0.0.0.0 255.255.255.0 U 202 0 0 eth0
192.168.40.0 0.0.0.0 255.255.255.0 U 303 0 0 wlan0
pi@octorpi4:~ $ ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.40.216 netmask 255.255.255.0 broadcast 192.168.40.255
inet6 fe80::5b3:1d1:f5b5:f412 prefixlen 64 scopeid 0x20<link>
inet6 fd25:5c48:ff7a:2abf:adfc:c2a6:a26:a47e prefixlen 64 scopeid 0x0<global>
ether d8:3a:dd:2d:94:01 txqueuelen 1000 (Ethernet)
RX packets 33600 bytes 8829836 (8.4 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 12871 bytes 2846036 (2.7 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 15260459 bytes 149844684327 (139.5 GiB)
TX packets 15260459 bytes 149844684327 (139.5 GiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.40.210 netmask 255.255.255.0 broadcast 192.168.40.255
inet6 fe80::4e3:2548:f9a9:8fd7 prefixlen 64 scopeid 0x20<link>
ether d8:3a:dd:2d:94:04 txqueuelen 1000 (Ethernet)
RX packets 15217981 bytes 1385045963 (1.2 GiB)
TX packets 111075812 bytes 1780343302 (1.6 GiB)
Didn't try
octoprint-systeminfo-20240516095629.zip (15.8 KB)
Google Nest WiFi Pro mesh router. Main node is connected to ethernet switch. Pi-hole on network to minimize ads. Router forwards DNS traffic to pihole. Works flawlessly. Wired and wireless devices are all on the same subnet. Laptop is a Mac running Sonoma 14.4.1, latest non beta OS. RPI4 boots from SSD disk attached to USB3. Not using the microSD card.
Having an ethernet cord run though a hallway across doorways is a safety hazard, especially in the evening. Not viable, except for testing. I've tried many "solutions", yet this Pi (and many of the other Pi's I have) just randomly drop off the network. It's quite frustrating. I don't think it's unique to OctoPi, but many of the Pi's suffer from a similar disease. My print server would go off the air a lot, fixed that by using ethernet, along with pihole. My sprinker controller running OpenSprinklerPi constantly disconnects, with exactly the same symptoms. Anyways, I'm here asking about Octopi. Any tips or guidance on this would be gratefully accepted.
