Stop
Please note that a GUI on the Pi is not needed for running OctoPrint. You should access it via the network from a browser somewhere on your network. The OctoPi image can in fact be run without ever having to attach a monitor to your Pi ("headless") as even the initial wifi configuration can be done just by editing
octopi-wpa-supplicant.txt
on the root of the SD when used as a thumb drive.Installing a desktop environment on your Pi running OctoPrint (e.g. via OctoPi) is not recommended and can be detrimental to performance and thus achievable print results.
OctoPi GUI Setup
A quick and easy guide to setting up OctoPi for beginners with zero experience. Follow these steps to setup OctoPi OS on your Raspberry Pi in a few basic steps regardless of your machine's operating system.
So what exactly is OctoPrint? Here is a list of things OctoPrint allows you to do:
- Wirelessly upload G-code files from a computer to a 3D printer
- Manually control a 3D printer (moving the X-, Y-, and Z-axes as well as forcing extrusion)
- Monitor print temperature and change print settings
- Set up a webcam to view the Print in real time and create time lapse videos
- Slice models using CuraEngine Legacy
- Customize operation with numerous plug-ins
Installation
Hardware Prerequisites:
- Raspberry Pi (Model 3B or later, Raspberry Pi Zero/Zero W not recommended)
- 5.1V/2.5 A Micro USB power supply (For the RPi)
- MicroSD card (preferably 16GB or larger)
- MicroSD card reader
- USB Mouse and Keyboard
- HDMI Monitor
- Stable WiFi
- Desktop/Laptop
Preparing the MicroSD Card:
Download the latest image of OctoPi from
OctoPrint.org - Download & Setup OctoPrint -
Next download an etching tool:
https://www.balena.io/etcher/ -
Insert the MicroSD card into the MicroSD card reader and connect it to your machine.
Format the MicroSD card (FAT32 formatting only)
Using Etcher, flash the disk image of the OctoPi OS onto the MicroSD card
Once the flashing is complete, insert the MicroSD card into the Raspberry Pi
Setting up the Raspberry Pi:
Connect the Raspberry Pi to the monitor, mouse and the keyboard and power it up.
Your Raspberry Pi will boot up automatically.
After the boot is complete, you will see the following:
octopi login:
pi
Password :
raspberry
You are now sucessfully logged in!
Enable GUI:
Enter the following command into the bash terminal:
sudo raspi-config
Re-enter the password.
Use the arrow keys to navigate to "Network Options"
Select "N2 Wi-fi"
Enter the SSID (Name of your Wifi network), and click "".
Enter the password of the Wifi (if none, leave blank), and click "".
Click
<Finish>
You are now back in the bash command line.
Enter:
sudo /home/pi/scripts/install-desktop
Enter the password, press any key to continue.
You will be asked whether you want the Pi to boot up into a desktop environment by default. Type βyesβ and hit Enter. We can disable this functionality later on if we want to.
The resources for the desktop GUI will now download and install automatically
When complete, Type:
sudo reboot
The Pi will now reboot to OctoPi Desktop GUI.
Enter the username and password.
Your OctoPi GUI is now ready!
Meta
Author: Harshit Shandilya, also on Github
Affero General Public License (AGPL)
