Octopi imaged but doesn't have wifi running
I have created an Octopi image on my Windows and then my Linux machines, but it’s not setting a config file to connect to the Wi-Fi. During the creation, I provided a SIDD and password, but I can't find a config file that contains that information. I am not able to access the octopi server using octopi.local, because it's not set up on wifi (the pi server)
I have made multiple attempts to set up the Octopus OS from Windows and Linux. I have looked on both images for a config file that contains my Wi-Fi information, and it does not exist.
no
The way the pi imager handles this is through a firstrun.sh file during flashing. There have been reports of an errant hard return being added to that file. You can find more information about it over here:
Also, depending on the model, it might only support 2.4GHz WiFi.
I got it working. Thank you.
