Banane
January 14, 2022, 2:13pm
1
i installed octopi but when i go to octopi.local
is because the octoprint is not started and I cannot start it
not working
raspberry pi 4 4gb
I'm not sure if I understand your problem correctly.
What happens when you go to http://octopi.local or http://octopi ?
Banane
January 14, 2022, 4:43pm
3
hallo ich habe den octopi 2 h laufen lasen und jetzt geht es
Abhängig von der SD-Karten Geschwindigkeit kann der erste Bootvorgang etwas Zeit in Anspruch nehmen.
Üblicherweise aber nicht mehr als 1-2 Minuten
Depending on the sd-card speed the first boot can take a while.
Usually it's no more than 1-2 minutes.
It can sometimes take a little while before the octopi.local host name works, eg if there's a different ip address in a DNS cache. On windows it can help to flush the DNS cache with ipconfig /flushdns
system
Closed
April 15, 2022, 9:17am
6
