I set up Octoprint on a Raspberry Pi 4. No problems. Changed the password from raspberry and I was able to see the web site on a browser on several other computers using the password I set up Octoprint with and still using pi as the sign in. I printed something uneventfully to test things.
Suddenly I can't access the server from the web interface. I get "Incorrect username or password."
I changed the password using raspi-config and again was able to get the server to start. But again using the web interface with the new password no luck. I also used WinStp to get into the server with the same password without issue.
I am using Firefox and I also tried Vivaldi to log in. I assume that the password and log in to access the server is the same as what is used to start Octoprint.
I did not try safe mode.
Latest version of Octoprint 1.6.1 and OctoPi 0.18. Win 11 preview version. Octoprint worked on it previously.
Without getting onto the web interface I am not sure how to get the System Information Dialog.
It seems that the password or login name somehow is different than the corresponding ones used to start the server.
I tested Octoprint on a Prusa 3ks.
