OctoPi loses connection after print starts; can't even ping the IP. Serial connection stays solid and prints complete successfully. This follows many successful prints that maintain network connection all the way through; the only recent changes are the addition of the RPi camera and a change in power supply; I added a 5.1V, 3A buck converter to eliminate undervoltage issues. Those have been solved.
Nothing. I just notice the connection vanishing. I usually notice the camera feed disappearing first. The print from last night lost connection after 21 minutes (20:16 start, 20:31 loss of network connection).
EDIT: I just lost connection again after visiting the GCode Viewer and Terminal tabs. I don't know whether that's related, but I definitely did not visit the Control tab. Server is now offline and I can't reconnect. Can't ping the IP address. All other network devices are fine.
Both octoprint and serial logs are here:
logs.zip (346.9 KB)
The serial log is just an excerpt because the print was very long and the log was HUGE.
Of note are these lines from octoprint.log:
2020-02-18 20:37:31,214 - octoprint.util.connectivity_checker - INFO - Connectivity changed from online to offline
2020-02-18 20:48:46,940 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:10.0.0.152
OctoPrint 1.3.12, OctoPi 0.17.0, Windows 10 PC, static IP assigned to both by router.
