I am trying to connect to my raspberry pi 3b running octopi. the installation went smoothly and and sent no errors. I cant see anything when I try to connect it to a monitor, and cannot connect in the terminal using ssh pi@octopi.local. I am on my apartments wifi an in order to connect it manually I need the MAC address and have no way of getting it.
I already tried re installing and trying to input the ssid and password through the raspberry pi imager and manually. I tried finding the MAC or IP address. I tried connecting to a monitor to access the pi and the tv said there was no hdmi connected.
I figured out how to connect it to the monitor, but I don't think it has even connected to the router yet. I attempted to use 'sudo iwlist wlan scan' to find the network but it wouldn't let me scroll through the results. In the 'octopi-wpa-supplicant.txt' file, I set ssid_scan = 1 to try and get it to find hidden networks, but when I run ifconfig, it says nothing has been sent or received. I am starting to think its a problem on the apartments end.
I believe you have a monitor and a keyboard on your RPi and you have a system that you used to write the SD card initially. As mentioned, ifconfig will show the MAC address(es) and you can capture the output of commands (including sudo iwlist wlan scan) using >logfile at the end of the command. Copy the output to /boot and you will be able to move the SD card back to your other system and upload the files.
You said you have an RPi 3B so only 2.4GHz WiFi is available. I assume you edited octopi-wpa-supplicant.txt with an editor that preserved the Unix line endings.
Hopefully, you now have enough "tools" to troubleshoot or capture information to upload so we can help.
