I recently upgrade our routers from the Apple Airport Extreme to the Google Wifi Mesh Routers. The changed the name of the network to a different name and the RaspberryPi's wouldn't work.
I amended the SSID and password in the config file and confirmed the correct country as well.
I still cannot see the RaspberryPi in my device list to be able to config. What could be the problem?
Logs (syslog, dmesg, ...)
