New to Octopi/Octoprint. Have Octopi on Raspberry Pi 4 - 4Gb. Prints start but never finish. Ender screen says "killed". prints fine from SD card. received 1 error about firmware not reporting temperatures properly- not sure if it's related.
Camera server also doesn’t work.
Installed Crealty Temperature plugin.
Safe Mode
All attempted print gcodes work fine from SD card but fail on Octoprint after approximately 30-45 minutes
Safe mode did not solve the issue. but it did present differently. Ender Pro Screen didn't say "Killed", the print head just stalled.
Complete Logs
Send: N21297 G1 X106.339 Y106.37 E841.40628*85
Recv: ok
Send: N21298 G1 X103.852 Y107.078 E841.45789*108
Recv: ok
Send: N21299 G1 X101.709 Y108.21 E841.50625*94
Recv: ok
Send: N21300 G1 X100.053 Y109.693 E841.55061*107
Recv: ok
Send: N21301 G1 X99.005 Y111.435 E841.59118*92
Recv: ok
Send: N21302 G1 X98.669 Y113.193 E841.6269*102
Recv: ok
Send: N21303 G1 X98.341 Y113.193 E841.63345*84
Recv: ok
Send: N21304 G1 X98.341 Y118.093 E841.73123*90
Recv: echo:Unknown command: "\x8fÔ)eÅI[×_ýü½¬¨©õqý\x7f\xffý\xff7\xffE\x06\x02"
Recv: ok
Send: N21305 G1 X98.568 Y118.093 E841.73576*82
Recv: Error:Line Number is not Last Line Number+1, Last Line: 21300
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: ok
Recv: echo:Unknown command: "111.435 E841.59118"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "113.193 E841.6269"
Recv: ok
Send: N21306 G1 X98.904 Y119.851 E841.77148*93
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "576"
Recv: ok
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: ".435 E841.59118"
Recv: ok
Recv: echo:Unknown command: "Y113.193 E841.63345"
Recv: ok
Send: N21307 G1 X99.953 Y121.593 E841.81206*87
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "*93"
Recv: ok
Recv: echo:Unknown command: "E841.59118"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "41 Y118.093 E841.73123"
Recv: ok
Recv: echo:Unknown command: "8.904 Y119.851 E841.77148"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "69 Y113.193 E841.6269"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: ".568 Y118.093 E841.73576"
Recv: ok
Send: N21308 G1 X101.608 Y123.076 E841.85641*102
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "Y121.593 E841.81206"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "301 G1 X99.005 Y111.435 E841.59118"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "1303 G1 X98.341 Y113.193 E841.63345"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "8 Y118.093 E841.73576"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "X99.953 Y121.593 E841.81206"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "9.005 Y111.435 E841.59118"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "303 G1 X98.341 Y113.193 E841.63345"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "568 Y118.093 E841.73576"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "\x80ù¿]T"
Recv: ok
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "2 G1 X98.669 Y113.193 E841.6269"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "X98.341 Y118.093 E841.73123"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "¸).$À¦\x80\x89ú?\x89!"
Recv: ok
Recv: echo:Unknown command: "4 Y119.851 E841.77148"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: ".341 Y118.093 E841.73123"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "Y119.851 E841.77148"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "005 Y111.435 E841.59118"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "23"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "X99.005 Y111.435 E841.59118"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: echo:Unknown command: "21303 G1 X98.341 Y113.193 E841.63345"
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: Resend: 21301
Recv: ok
Recv: ok
Send: N21309 G1 X103.752 Y124.208 E841.90479*106
Recv: Resend: 21301
Printer keeps requesting line 21301 again and again, communication stuck
Changing monitoring state from "Printing" to "Error: Printer keeps requesting line 21301 again and again, communication stuck"
Send: M112
Send: N21310 M112*32
Send: N21311 M104 T0 S0*33
Send: N21312 M140 S0*102
Changing monitoring state from "Error: Printer keeps requesting line 21301 again and again, communication stuck" to "Offline (Error: Printer keeps requesting line 21301 again and again, communication stuck)"
Closing down send loop
Octoprint Version: Version 1.4.2
Octopi version: Version 0.17.0, running on Raspberry Pi 4 Model B Rev 1.2
Printer: Crealty Ender 3 Pro
Firmware: not sure. Purchased printer about 2 months ago.
OS: tried from Win10 on new MS Edge (firefoxish one) and iPhone XR (IOS 13.7) with app. always same results.
