I'm trying to have a newly installed OctoPrint instance on RPI Zero 2 W (I've been using an RPI 4 so far and it worked), to connect with my MP Minidelta V2. However when trying to connect, I continue to get timeouts.
No answer from the printer within the connection timeout, trying another hello
Send: N0 M110 N0*125
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
- installed Malyan Connection Fix
- used 3-4 different cables
- I reinstalled with a 32-bit buster image
- I tried installing an updated version of CH341 drivers (How to Install CH340 Drivers - SparkFun Learn)
- I checked with cu if there's some message from the printer (there are: "start" "echo PowerUp" "Marlin 1.1.5" some other initial printer diagnostic and then starts sending temperature)
Yes
octoprint-systeminfo-20231112173804.zip (63.8 KB)
Octoprint version: 1.8.6
Octopi version: 0.18.0 (installed from image octopi-0.18.0-1.8.6-20221018093204.zip)
Printer: Monoprice MInidelta V2
Firmware: 1.1.5 (Motor), (LCD) 1.4.2
Port: ttyUSB0 (activated also ttyAMA0 and ttyS0 but useless)
