My Raspberry Pi 4b (4GB RAM) eventually (after about 6-24 hours) won't load the web interface and if I look at the display I can see an error report that says "Timeout waiting for hardware interrupt" among many other things. Picture in logs section.
I've tried reloading (wiping the SD Card) octopi with no plugins and reverting to the firmware that the Pi 4 ships with (which actually made the webcam [logitech C615] work better) but I still have the problem.
octoprint.log (476.1 KB)
serial.log (148 Bytes)
I'm using Octopi 17.0 and octoprint 1.3.12 on my Pi 4b. Webcam is a logitech C615. Also using a logitech K400+ keyboard, FWIW, and a samsung syncmaster 2233 monitor. My printer is a modified Creality Ender 4 that I've converted to CoreXY and I'm using a Duet 2 wifi controller board. Duet 2 firmware is v2.04. Pi 4b firmware is 00013701. Browser is Firefox 70.0.1 64-bit. OS is Windows 10 1903 build 18362.476.
