This is not an issue per se but rather an idea.
Basically I have an Ender 3 pro with SKR mini E3 V2.0 motherboard on Marlin, a Bigtree TFT35 E3 V2.0 screen and Raspberry PI 4 running Octoprint.
Right now I am using the following setup:
Pi4 --> Marlin (via USB)
TFT35 --> Marlin (via TFT pins on motherboard)
The setup works fine except for I'd like to: 1) eliminate USB connection; 2) Continue to use TFT35 with touch mode and ideally let Octopi talk to TFT35 to sync status.
I came across this thread on github: https://github.com/bigtreetech/BIGTREETECH-TouchScreenFirmware/issues/281, which proposes a solution to connect PI->TFT->Marlin. The solution solves my problem but apparently there are some lagging issues as TFT is in the middle handling the Pi <-> Marlin traffic.
Given that PI4 has 5 PL011 UARTs, I am wondering if it is possible to have Marlin<->Pi<->TFT passthrough. Is this physically feasible? It looks like hooking two UARTs on Pi and forward signals is possible but I would assume there are more than that (e.g., what if Pi and TFT talks to Marlin in the same time).
I just like to ask around and see anyone has some insight on the feasibility of this idea.
