When I shut down the Pi it automatically reboots, but only when powered via buck converter connected to the printer PSU
Removed serial connection to mainboard TFT connector, no change. Moved buck converter power from header to micro USB, no change. Also tried lifting the ground from the buck converter, no change. Then tried two different isolated power sources via Micro USB, no reboot after shutdown.
Complete Logs
Logs are attached, shutdown event is at 10:43:09. It was triggered from the printer UI using the M118 GCode command interpreted by the Action Commands plugin.
OctoPrint 1.4, OctoPi 17 running on RPi 3+, Ender 3 Pro, Marlin 2.0.x bugfix on SKR 1.3, Firefox (latest), MacOS and iOS (latest)
My Pi is powered via a buck converter (voltage output confirmed to be 5.1v, rated for 2.5A) powered from my Ender 3's PSU and connected to the 5v and gnd pins on the Pi's header. Whether I shut down from the OctoPrint UI or terminal command "sudo shutdown -h now" the Pi shuts down then immediately reboots. It only reboots this way when powered from the buck converter; if I power from a separate power source it stays shut down, so I think this is more of a hardware issue. I've also tried disconnecting the serial connection to the SKR 1.3's TFT port to confirm that the ground to the mainboard isn't the culprit and the problem persists.
logs.zip (86.9 KB)
