Octoprint can't start, i can ssh to the raspberry and when i go for a sudo apt update i get the "no space left on device" error.
I have a 32gb card and when i run ncdu i get:
138,6 MIB - /octoprint
128,8 MIB - /.octoprint
61,5 MIB - /.cache
and some other under MIB size so the card is not full.
If i run sudo fdisk -l i get this on the (linux) partition:
Device | Start | End | Sectors | Size | Type
/dev/mmcblk0p2 | 532480 | 62521343 | 61988864 | 29,6G | Linux
If i run sudo df -h i get this:
Filesystem | Size | Used | Avail | Use% | Mounted on
/dev/root | 30G | 29G | 0 | 100% | /
sudo raspi-config and expand filesystem
Tried deleting all i could but it still says full.
Tried stopping and restarting the daemon and services to see if they held on to files that couldn't delete but the commands from above says otherwise
Linux boots just fine but it seems like a faulty card or some other error?
All the logs for serial and octoprint are blank so nothing there...
Yes
Impossible to provide this since i can't get octoprint to start?
The commandline only gives me:
Could not initialize settings manager_ [Errno 28] No space left on device
There was a fatal error in initializing the platform
but it says this in the beginning atleast:
OctoPrint version : 1.7.2
OctoPi version: 0.17.0
Ender 3 pro, Octopi on a raspberry pi 4 with a 32gb sandisk ultra sd card using wifi
