Octopi serial port not found
Octopi can't find the serial port after a new flash and restore from backup.
Version 1.1.0, running on Raspberry Pi Zero 2 W Rev 1.0
Made necessary changes to /boot/firmware/config.txt and /boot/firmware/cmdline.txt.
SSH into octopi, cd to /boot/firmware. Use your favorite editor (as root) to insert the following line at the end of config.txt:
dtoverlay=miniuart-bt
Now edit cmdline.txt (as root) and remove the following text:
console=serial0,baud=115200
Reboot and all should work.
Not necessary
NA
I used this website as a guide. I used the Raspberry Pi Imager to flash the new image to the SD card. After the first boot I restored a backup made with the previous image. All worked as expected other than the serial port problem.
Hello @MrPorcine !
This forum works different than others.
Please add your solution in a new post and tick the "Solution" checkbox.
This way other users can benefit from your experience.
Thank you.
It turns out that the octopi image "OctoPi (Raspberry Pi)" I downloaded from here didn't include the changes necessary to use gpio pins 14 and 15 for a serial port. I used the Raspberry Pi Imager to flash the new image to the SD card. Make sure you add the options to the Imager to wake up SSH and give it a useful username and password. When you boot the new SD card everything should work except octopi can't find a serial port. Here's how to fix it:
It's possible that the console=serial0 entry is automatically added after the first boot after adding the dtoverlay line to config.txt. If you don't see console=serial0 in cmdline.txt, reboot again.
