Logitech C310 or Logitech C920 (Not connected at the same time)
octoprint-systeminfo-20211023185204.zip (45.9 KB)
After having experienced problems updating Octopi to v1.7.0, I finally pulled myself together and updated Python from 2.7 to 3.x (I performed the system backup, installed the new image 0.1.8.0 and restored the backup) Everything went just fine except the webcam stream now looks garbled from both my webcams. They both worked perfectly before. I far as I understand it should not be necessary to fiddle with the webcam.txt file via SSH anymore, as Octopi should be able to setup the camera correctly. But how do I select a higher resoulution than 640x480, then?
I have have downloaded and installed "Camera Settings 0.3.0" from Taylor Talkington to be able to monitor the chosen camera settings. It seems, from the camera ID, that both my camera are detected correctly.
Wecam logfile:
**Starting up webcamDaemon...
cfg_file:      /boot/octopi.txt
camera:        auto
usb options:   -r 640x480 -f 10
raspi options: -fps 10
http options:  -w ./www-octopi -n --listen 127.0.0.1
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Dec  2 12:56:19 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
 i: Frames Per Second.: 10
 i: Format............: JPEG
Goodbye...
 o: HTTP Listen Address..: 127.0.0.1
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 21 20:53:30 root: Starting USB webcam
Goodbye...
Unable to dequeue buffer: No such device
 i: Error grabbing frames
 i: cleaning up resources allocated by input thread
Unable to stop capture: No such device
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 21 21:13:06 root: Starting USB webcam
Goodbye...
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 22 17:07:02 root: Starting USB webcam
Goodbye...
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 22 17:46:59 root: Starting USB webcam
Goodbye...
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 22 18:02:29 root: Starting USB webcam
Goodbye...
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 22 18:07:31 root: Starting USB webcam
Goodbye...
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 22 19:41:50 root: Starting USB webcam
Goodbye...
Octopi version 1.7.0 on Raspberry 3
 By default I would like to enable the Logitech C310 camera in 1280x720 mode.
