Octopi showing garbled webcam stream
Logitech C310 or Logitech C920 (Not connected at the same time)
Octopi webcam picture
octoprint-systeminfo-20211023185204.zip (45.9 KB)
After having experienced problems updating Octopi to v1.7.0, I finally pulled myself together and updated Python from 2.7 to 3.x (I performed the system backup, installed the new image 0.1.8.0 and restored the backup) Everything went just fine except the webcam stream now looks garbled from both my webcams. They both worked perfectly before. I far as I understand it should not be necessary to fiddle with the webcam.txt file via SSH anymore, as Octopi should be able to setup the camera correctly. But how do I select a higher resoulution than 640x480, then?
I have have downloaded and installed "Camera Settings 0.3.0" from Taylor Talkington to be able to monitor the chosen camera settings. It seems, from the camera ID, that both my camera are detected correctly.
Wecam logfile:
**Starting up webcamDaemon...
--- Configuration: ----------------------------
cfg_file:      /boot/octopi.txt
camera:        auto
usb options:   -r 640x480 -f 10
raspi options: -fps 10
http options:  -w ./www-octopi -n --listen 127.0.0.1
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Dec  2 12:56:19 root: Starting USB webcam
Checking for VL805 (Raspberry Pi 4)...
  - It seems that you don't have VL805 (Raspberry Pi 4).
    There should be no problems with USB (a.k.a. select() timeout)
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
 i: Desired Resolution: 640 x 480
 i: Frames Per Second.: 10
 i: Format............: JPEG
Done bring up all configured video device
Goodbye...
UVCIOC_CTRL_ADD - Error at Pan (relative): Inappropriate ioctl for device (25)
UVCIOC_CTRL_ADD - Error at Tilt (relative): Inappropriate ioctl for device (25)
UVCIOC_CTRL_ADD - Error at Pan Reset: Inappropriate ioctl for device (25)
UVCIOC_CTRL_ADD - Error at Tilt Reset: Inappropriate ioctl for device (25)
UVCIOC_CTRL_ADD - Error at Pan/tilt Reset: Inappropriate ioctl for device (25)
UVCIOC_CTRL_ADD - Error at Focus (absolute): Inappropriate ioctl for device (25)
UVCIOC_CTRL_MAP - Error at Pan (relative): Inappropriate ioctl for device (25)
UVCIOC_CTRL_MAP - Error at Tilt (relative): Inappropriate ioctl for device (25)
UVCIOC_CTRL_MAP - Error at Pan Reset: Inappropriate ioctl for device (25)
UVCIOC_CTRL_MAP - Error at Tilt Reset: Inappropriate ioctl for device (25)
UVCIOC_CTRL_MAP - Error at Pan/tilt Reset: Inappropriate ioctl for device (25)
UVCIOC_CTRL_MAP - Error at Focus (absolute): Inappropriate ioctl for device (25)
UVCIOC_CTRL_MAP - Error at LED1 Mode: Inappropriate ioctl for device (25)
UVCIOC_CTRL_MAP - Error at LED1 Frequency: Inappropriate ioctl for device (25)
UVCIOC_CTRL_MAP - Error at Disable video processing: Inappropriate ioctl for device (25)
UVCIOC_CTRL_MAP - Error at Raw bits per pixel: Inappropriate ioctl for device (25)
 o: www-folder-path......: ./www-octopi/
 o: HTTP Listen Address..: 127.0.0.1
 o: commands.............: disabled
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 21 20:53:30 root: Starting USB webcam
Goodbye...
Unable to dequeue buffer: No such device
 i: Error grabbing frames
 i: cleaning up resources allocated by input thread
Unable to stop capture: No such device
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 21 21:13:06 root: Starting USB webcam
Goodbye...
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 22 17:07:02 root: Starting USB webcam
Goodbye...
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 22 17:46:59 root: Starting USB webcam
Goodbye...
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 22 18:02:29 root: Starting USB webcam
Goodbye...
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 22 18:07:31 root: Starting USB webcam
Goodbye...
camera:        auto
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Oct 22 19:41:50 root: Starting USB webcam
Goodbye...
Octopi version 1.7.0 on Raspberry 3
Could be under voltage.
Try to power the pi off, disconnect all usb devices except the webcam (inlc the printer), power the pi back up and try again.
Apart from the webcam, the only connected device is the 3D printer itself. I have tried to disconnect that as well, but unfortunately without any positive result. Both webcams worked perfecly before I performed the upgrade. So I suggets that it must have something to do with some software settings / parameters.
Anyway - thanks for your suggestion. It was worth trying.
Where'd you get this information from? The way to configure the cameras hasn't changed, it is still /boot/octopi.txt.
Well, I might have misunderstood the meaning, but I have read it here:
OctoPrint.org - Download & Setup OctoPrint
"You also do not need to manually enable the RaspiCam** if you have one, that is already taken care of on the image as well."
But assuming I need to add the parameters myself in "octopi.txt" and looking at the camera list here:
USB webcams known to work with mjpg-streamer
I'm a bit confused what line I need to add/edit in "Octopi.txt" Maybe you can help me? :slightly_smiling_face: By default I would like to enable the Logitech C310 camera in 1280x720 mode.
octopi.txt.log (2.9 KB)
Don't mind the "log" name of "octopi.txt". I had to rename it in order to be allowed to upload it.
Thank you in advance for your help and support.
hi, i'm having the same issue with C270 webcam. What did you do to solve it?
Hello @nicoautoxp !
Afaik, it's not solved.
I was able to fix it by restarting the webcam stream. I wrote short shell script to restart it and made a button in home assistant to run it. I could look it up if you're interested.
