The UI buttons for shutdown/restart tell "command sent successfully," but nothing happens and when I ssh in and check the octoprint service log, I see:
Mar 28 07:03:46 prusa octoprint[1294]: 2024-03-28 07:03:46,016 - octoprint.server.api.system - INFO - Performing command for core:shutdown: /scripts/system_shutdown.sh
Mar 28 07:03:46 prusa octoprint[1294]: 2024-03-28 07:03:46,590 - octoprint.server.api.system - WARNING - Command for core:shutdown failed with return code 127:
Mar 28 07:03:46 prusa octoprint[1294]: !
Mar 28 07:03:46 prusa octoprint[1294]: ! STDOUT:
Mar 28 07:03:46 prusa octoprint[1294]: ! STDERR:
Mar 28 07:03:46 prusa octoprint[1294]: ! /bin/sh: 1: /scripts/system_shutdown.sh: not found
And when I do an update through the UI, it reports that it could not restart as an error. There is no /scripts/ folder:
$ ls /
bin boot dev etc home lib lost+found media mnt opt proc root run sbin srv sys tmp usr var
There is a folder like that in home dir, but it doesn't contain the needed file:
$ ls $HOME
OctoPrint mjpg-streamer oprint scripts
$ ls $HOME/scripts
add-octoprint-checkout install-desktop safemode welcome
I have this problem for few weeks, but I didn't get to doing a proper diagnostics, re-flashing the SD cards... and a bug report until now. So it is not something that would break just now.
I downloaded a fresh OctoPi image through Raspberry Pi Imager, both stable and with the new webcam stack. I tried to find the missing script via find / -name system_shutdown.sh and it was not found. I tried to use a different SD card in case of some really weird consistent corruption, but there was no difference either.
no, issue is not related to the running server but missing files
n/a
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/122.0.0.0 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 900.0
env.hardware.ram: 912715776
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 2 Model B Rev 1.1
env.plugins.pi_support.octopi_camera_stack: webcamd
env.plugins.pi_support.octopi_version: 1.0.0
env.plugins.pi_support.octopiuptodate_build: 1.0.0-1.9.3-20231009151442
env.plugins.pi_support.octopiuptodate_build_short: 2023.10.09.151442
env.python.pip: 22.3
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.9.3
systeminfo.generated: 2024-03-28T07:42:55Z
systeminfo.generator: zipapi
- RPi 2B
- latest stable Raspberry Pi Imager (1.8.5)
- OctoPi freshly downloaded (1.0.0 with octoprint 1.9.3)
