I can't scroll on the web and the error is displayed:
Hi ![]()
Please don't delete the template - it's there for a reason. It tells us a lot of important information that we need to help you.
The most important parts are 1. try safe mode and 2. upload a systeminfo bundle .zip.
If you're able to click anything in the webui, you should be able to enable safe mode and download the bundle from there - otherwise you can do it via ssh.
Click on the blue words for further information.
Alternatively, to get to safe mode, go to /recovery on your OctoPrint server and select it from there.
Puede entrar con el modo seguro y logré actualizar después de eliminar algún complemento, gracias por la ayuda.
