Octopi Won't connect to Ender 3 Pro
Had a working Octoprint server with my Ender 3 Pro. Upgraded to BLTouch and started updating Marlin 2.1.x Bugfix and now Octoprint will not connect to printer
Send: N0 M110 N0125
No answer from the printer within the connection timeout, trying another hello
Send: N0 M110 N0
125
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
Verified connection/cable with Pronterface. Rebooted Octoprint. Tried changing baudrate in Marlin (reduce). Tried disconnecting camera (in case it was drawing too much USB power).
YES
octoprint-systeminfo-20240807162329.zip (89.8 KB)
Just tried and it connects.
Yes
RPi 4 Mode b 4gb. Ender 3 Pro with Creality 4.2.7 32 bit board. USB connection with USB Power Isolate. Logitech Camera (disconnected at present). Pi hard wired to network. Marlin 2.1.x Bugfix (from 8/4/2024) recently installed BL-Touch configuring Marlin to support upgrading from manual mesh.Running latest Octoprint everything (AFAIK) i.e. no upgrades available
I'm guessing the next debug steps will be to undo all plugins and reinstall 1 at a time to see what is causing failure.
Well ... looking at the plugins I found virtual printer. Disabling that solved the communications problem. I do not remember adding it but I will certainly delete it!
Hello @Daniel_Hempy !
It comes in by default. Disabling is enough. You may use the thing some day.
