I have been using Octoprint with a Prusa i3 clone and it has been working like a champ. Recently I got a cheap CR10 clone and setup a new Octopi server on a Raspberry Pi 3B.
Octoprint seems to detect the printer, connect to it, but after that, fails with errors like the following
Recv: Error:No Line Number with checksum, Last Line: 0
Send: N1 M115*39
Recv: echo:SD card ok
Send: N2 M20*19
Send: N3 M105*36
Send: N4 M105*35
Send: N5 M105*34
Send: N6 M105*33
Send: N7 M105*32
Send: N8 M105*47
I've tried different baud rates, it fails with all other ones except for the one it auto detects.
I've tried swapping USB cable (with the one that was working for the i3 clone), no dice.
If I start print from SD Card it prints (kind of, currently clogged itself up because the fan wasn't working, that's a different story).
-I don't think it is an Octoprint bug, could be the USB serial chip has a weirdness because the SD card that came with it has some drivers which I am sure don't work for Linux.
Octoprint version: 1.3.9
OctoPi version: 0.15.1
Printer: A generic Chinese printer called Lymstar E10
Firmware: Marlin 1.1.4
Here is what the connection looks like
Serial port list: ['/dev/ttyUSB0', '/dev/ttyUSB0']
Trying /dev/ttyUSB0
Connecting to: /dev/ttyUSB0
Connected to: Serial<id=0x6ca0cb30, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 115200
Send: N0 M110 N0*125
Recv: start
Changing monitoring state from "Detecting baudrate" to "Operational"
Recv: echo: External Reset
Recv: Marlin 1.1.4
Recv:
Recv: echo: Last Updated: 2017-07-04 12:00 | Author: (none, default config)
Recv: Compiled: Jan 8 2018
Recv: echo: Free Memory: 2153 PlannerBufferBytes: 1264
Recv: Here=0
Recv: echo:EEPROM version mismatch (EEPROM=? Marlin=V05)
Recv: echo:Hardcoded Default Settings Loaded
Recv: echo: G21 ; Units in mm
Recv: echo: M149 C ; Units in Celsius
Recv:
Recv: echo:Filament settings: Disabled
Recv: echo: M200 D3.00
Recv: echo: M200 D0
Recv: echo:Steps per unit:
Recv: echo: M92 X80.00 Y80.00 Z400.00 E402.00
Recv: echo:Maximum feedrates (units/s):
Recv: echo: M203 X300.00 Y300.00 Z5.00 E25.00
Recv: echo:Maximum Acceleration (units/s2):
Recv: echo: M201 X3000 Y3000 Z100 E10000
Recv: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
Recv: echo: M204 P800.00 R800.00 T1000.00
Recv: echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_ms> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
Recv: echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.40 E5.00
Recv: echo:Home offset:
Recv: echo: M206 X11.20 Y14.20 Z0.00
Recv: echo:Material heatup parameters:
Recv: echo: M145 S0 H200 B60 F0
Recv: M145 S1 H240 B80 F0
Recv: echo:PID settings:
Recv: echo: M301 P20.00 I1.00 D95.00
Recv: echo:LCD Contrast:
Recv: echo: M250 C32
Send: N1 M115*39
Send: N2 M20*19
Send: N3 M105*36
Send: N4 M105*35
Send: N5 M105*34
Send: N6 M105*33
I would like to upgrade to the latest Marlin, only if I could find all the custom settings for the printer. I've asked the vendor and waiting for response.
Any pointers or guidance, much appreciated. Thanks.
