Some plugins fail to load/work after an upgrade to 1.11.7, because setuptools is upgraded too (to 82.0.0)
The pkg_resources package is not present anymore in setuptools 82.0.0 (it may have disappeared on an earlier release). So any plugin that still requires pkg_resource will fail to load.
Currently (as far as the plugins I use) :
- PrintTimeGenius (solved with the 2.4.2 release)
- ExcludeRegion (as an aside, is this plugin alive ?)
For ExcludeRegion, either disable the plugin, or patch it :
*** OctoPrint-ExcludeRegionPlugin-master/octoprint_excluderegion/__init__.py 2022-12-08 01:55:45.000000000 +0100
--- OctoPrint-ExcludeRegionPlugin-master.nv/octoprint_excluderegion/__init__.py 2026-02-24 23:07:54.504434800 +0100
*** 38,45 ****
import flask
from flask_login import current_user
- import pkg_resources
import octoprint.plugin
from octoprint.events import Events
from octoprint.settings import settings
--- 38,43 ----
*** 162,179 ****
def get_assets(self):
"""Define the static assets the plugin offers."""
- octoprintVersion = pkg_resources.parse_version(octoprint.__version__)
jsFiles = ["js/excluderegion.js"]
- # The modified gcode renderer is not needed for 1.3.10rc1 and above
- if (octoprintVersion < pkg_resources.parse_version("1.3.10rc1")):
- self._logger.info(
- "Octoprint {} is pre 1.3.10rc1, including renderer.js to override gcode viewer",
- octoprint.__display_version__
- jsFiles.insert(0, "js/renderer.js")
return dict(
js=jsFiles,
css=["css/excluderegion.css"]
--- 160,168 ----
