Latest OctoPrint 1.3.11 Update Fails Via Web Interface. I'm currently running 1.3.10 OctoPrint and OctoPi Version 0.15.1, running on Raspberry Pi 3 Model B Rev 1.2
All I've tried to do is restart the Raspberry Pi
I've attached the required logs, and have pasted in the messages I get when trying to update. I don't have a clue other than some sort of certificate error or it seems like maybe PIP needs updated?
octoprint.log (31.4 KB)
plugin_softwareupdate_console.log (9.4 KB)
Text while updating:
Updating, please wait.
Now updating OctoPrint to 1.3.11
/home/pi/oprint/bin/python2 -m pip install https://github.com/foosel/OctoPrint/archive/1.3.11.zip --no-cache-dir
Collecting https://github.com/foosel/OctoPrint/archive/1.3.11.zip
Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)'),)': /foosel/OctoPrint/zip/1.3.11
Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)'),)': /foosel/OctoPrint/zip/1.3.11
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)'),)': /foosel/OctoPrint/zip/1.3.11
Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)'),)': /foosel/OctoPrint/zip/1.3.11
Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)'),)': /foosel/OctoPrint/zip/1.3.11
Exception:
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/commands/install.py", line 324, in run
requirement_set.prepare_files(finder)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/req/req_set.py", line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/req/req_set.py", line 620, in _prepare_file
session=self.session, hashes=hashes)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/download.py", line 821, in unpack_url
hashes=hashes
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/download.py", line 659, in unpack_http_url
hashes)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/download.py", line 853, in _download_http_url
stream=True,
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/requests/sessions.py", line 521, in get
return self.request('GET', url, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/download.py", line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/requests/sessions.py", line 508, in request
resp = self.send(prep, **send_kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/requests/sessions.py", line 640, in send
history = [resp for resp in gen] if allow_redirects else []
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/requests/sessions.py", line 218, in resolve_redirects
**adapter_kwargs
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/requests/sessions.py", line 618, in send
r = adapter.send(request, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/requests/adapters.py", line 506, in send
raise SSLError(e, request=request)
SSLError: HTTPSConnectionPool(host='codeload.github.com', port=443): Max retries exceeded with url: /foosel/OctoPrint/zip/1.3.11 (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661)'),))
You are using pip version 9.0.3, however version 19.1.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
The update did not finish successfully. Please consult octoprint.log and plugin_softwareupdate_console.log for details.
