Initially was working with my 1st time booting up. After I update to the latest stable update. It is unable to detect my printer. Camera stream still working normally, Port is set to auto and baud rate are set to 115200. My printer is Ender-3. An error keep saying :
State: Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)
Not sure where to start, still new to Octoprint.
I tried in safe mode but still remain the same issue.
Nope.
Complete Logs
Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@115200
Trying port /dev/ttyUSB0, baudrate 115200
Connecting to port /dev/ttyUSB0, baudrate 115200
Unexpected error while connecting to serial port /dev/ttyUSB0, baudrate 115200 from hook default: SerialException: '[Errno 5] could not open port /dev/ttyUSB0: [Errno 5] Input/output error: '/dev/ttyUSB0'' @ comm.py:_open_serial:3670
Could not open port /dev/ttyUSB0, baudrate 115200, skipping
Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
I am using Raspberry Pi 4 Model B 2GB, Ender-3, Octoprint1.5.2.
