Since updating to Octoprint 1.8.0 and now 1.8.1 Octoprint hangs or crashes completely after some time sporadically. Needs power on reset on Raspberry Pi Zero 2 W to solve it (but also after restart sometimes the Octoprint service hangs with 100% CPU load making the Raspi unaccessible over the network / cannot even ping it)
The issue occurred 1st time after updating to 1.8.0 and doing a print, at the end of the print (5-6h) Octoprint was no longer reachable on the network so I restarted the Raspi.
After updating to 1.8.1 initially there were no issues, but now Octoprint / the raspberrypi is not reachable at all most of the time (only by chance I can login into the console). However when I do it I can see Octoprint utilizing 100% CPU all the time. Only thing that happens is that my LED stripe gets turned on by Octoprint.
Reboot, Restart
Not possible since Octoprint currently does not startup or stops hanging
n/a
n/a not accessible currently
2022-05-25 23:28:03,856 - octoprint.startup - INFO - ******************************************************************************
2022-05-25 23:28:03,860 - octoprint.startup - INFO - Starting OctoPrint 1.8.1
2022-05-25 23:28:03,862 - octoprint.startup - INFO - ******************************************************************************
2022-05-25 23:28:24,009 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1000.0
| ram: 382574592
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| model: Raspberry Pi Zero 2 W Rev 1.0
| octopi_version: 0.18.0
| throttle_state: '0x0'
| python:
| pip: 20.3.3
| version: 3.7.3
| virtualenv: /home/pi/oprint
Errors starting from here:
2022-05-25 23:57:41,756 - octoprint.plugins.octoeverywhere - INFO - Frontend http port detected as 80, is https? False
2022-05-25 23:57:41,785 - octoprint.plugins.octoeverywhere - INFO - Attempting to talk to OctoEverywhere, server con wss://starport-v1.octoeverywhere.com/octoclientws[1]
2022-05-25 23:57:41,793 - octoprint.plugins.octoeverywhere - ERROR - OctoEverywhere Ws error: [Errno -3] Temporary failure in name resolution
2022-05-25 23:57:41,793 - websocket - ERROR - error from callback <function Client.__init__.<locals>.onClosed at 0x66a64810>: onClosed() takes 1 positional argument but 3 were given
2022-05-25 23:57:41,793 - octoprint.plugins.octoeverywhere - ERROR - OctoEverywhere Ws error: onClosed() takes 1 positional argument but 3 were given
2022-05-25 23:57:41,794 - octoprint.plugins.octoeverywhere - INFO - Disconnected from OctoEverywhere, server con wss://starport-v1.octoeverywhere.com/octoclientws[1]
2022-05-25 23:57:41,794 - octoprint.plugins.octoeverywhere - INFO - Sleeping for 5 seconds before trying again.
2022-05-25 23:57:41,931 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://octopi.local/', 'path': '/', 'query_string': 'l10n=de'}
2022-05-25 23:57:44,496 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:57:46,798 - octoprint.plugins.octoeverywhere - INFO - Attempting to talk to OctoEverywhere, server con wss://starport-v1.octoeverywhere.com/octoclientws[2]
2022-05-25 23:57:46,799 - octoprint.plugins.octoeverywhere - ERROR - OctoEverywhere Ws error: [Errno -3] Temporary failure in name resolution
2022-05-25 23:57:46,800 - websocket - ERROR - error from callback <function Client.__init__.<locals>.onClosed at 0x66c0dcd8>: onClosed() takes 1 positional argument but 3 were given
2022-05-25 23:57:46,800 - octoprint.plugins.octoeverywhere - ERROR - OctoEverywhere Ws error: onClosed() takes 1 positional argument but 3 were given
2022-05-25 23:57:46,800 - octoprint.plugins.octoeverywhere - INFO - Disconnected from OctoEverywhere, server con wss://starport-v1.octoeverywhere.com/octoclientws[2]
2022-05-25 23:57:46,801 - octoprint.plugins.octoeverywhere - INFO - Sleeping for 14 seconds before trying again.
2022-05-25 23:57:49,616 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:57:50,132 - octoprint.server.util.flask - INFO - Passively logging in user Ronny from 127.0.0.1
2022-05-25 23:57:50,135 - octoprint.access.users - INFO - Logged in user: Ronny
2022-05-25 23:57:54,701 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:57:59,720 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:00,817 - octoprint.plugins.octoeverywhere - INFO - Attempting to talk to OctoEverywhere, server con wss://starport-v1.octoeverywhere.com/octoclientws[3]
2022-05-25 23:58:00,825 - octoprint.plugins.octoeverywhere - ERROR - OctoEverywhere Ws error: [Errno -3] Temporary failure in name resolution
2022-05-25 23:58:00,828 - websocket - ERROR - error from callback <function Client.__init__.<locals>.onClosed at 0x62e76780>: onClosed() takes 1 positional argument but 3 were given
2022-05-25 23:58:00,829 - octoprint.plugins.octoeverywhere - ERROR - OctoEverywhere Ws error: onClosed() takes 1 positional argument but 3 were given
2022-05-25 23:58:00,829 - octoprint.plugins.octoeverywhere - INFO - Disconnected from OctoEverywhere, server con wss://starport-v1.octoeverywhere.com/octoclientws[3]
2022-05-25 23:58:00,829 - octoprint.plugins.octoeverywhere - INFO - Sleeping for 31 seconds before trying again.
2022-05-25 23:58:04,731 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:09,743 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:14,794 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:19,819 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:24,845 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:28,244 - octoprint.server.preemptive_cache - INFO - ... done in 46.31s
2022-05-25 23:58:28,245 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://192.168.178.115/', 'path': '/', 'query_string': 'l10n=de'}
2022-05-25 23:58:28,487 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:49.183, compression:0.166] [929347->139029 14.960%] /
2022-05-25 23:58:29,857 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:30,595 - octoprint.server.preemptive_cache - INFO - ... done in 2.35s
2022-05-25 23:58:31,861 - octoprint.plugins.octoeverywhere - INFO - Attempting to talk to OctoEverywhere, server con wss://starport-v1.octoeverywhere.com/octoclientws[4]
2022-05-25 23:58:31,865 - octoprint.plugins.octoeverywhere - ERROR - OctoEverywhere Ws error: [Errno -3] Temporary failure in name resolution
2022-05-25 23:58:31,866 - websocket - ERROR - error from callback <function Client.__init__.<locals>.onClosed at 0x62b79d68>: onClosed() takes 1 positional argument but 3 were given
2022-05-25 23:58:31,867 - octoprint.plugins.octoeverywhere - ERROR - OctoEverywhere Ws error: onClosed() takes 1 positional argument but 3 were given
2022-05-25 23:58:31,868 - octoprint.plugins.octoeverywhere - INFO - Disconnected from OctoEverywhere, server con wss://starport-v1.octoeverywhere.com/octoclientws[4]
2022-05-25 23:58:31,868 - octoprint.plugins.octoeverywhere - INFO - Sleeping for 67 seconds before trying again.
2022-05-25 23:58:34,872 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:39,889 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:44,901 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:49,917 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:54,937 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:58:59,954 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:59:04,971 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:59:09,986 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-25 23:59:45,970 - octoprint.startup - INFO - ******************************************************************************
2022-05-25 23:59:45,976 - octoprint.startup - INFO - Starting OctoPrint 1.8.1
2022-05-25 23:59:45,979 - octoprint.startup - INFO - ******************************************************************************
2022-05-25 23:59:52,974 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: offline
2022-05-25 23:59:52,974 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is not working
2022-05-25 23:59:52,975 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is not working
2022-05-25 23:59:53,000 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2022-05-25 23:59:53,018 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2022-05-26 00:00:05,489 - octoprint.plugins.ws281x_led_status - INFO - Detected running on a Raspberry Pi Zero
2022-05-26 00:00:05,779 - octoprint.startup - INFO - Added settings overlay from plugin dashboard
2022-05-26 00:00:05,844 - octoprint.plugin.core - INFO - Found 39 plugin(s) providing 39 mixin implementations, 84 hook handlers
2022-05-26 00:00:06,195 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2022-05-26 00:00:06,257 - octoprint.server - INFO - Intermediary server started
2022-05-26 00:00:06,313 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2022-05-26 00:00:06,621 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2022-05-26 00:00:06,632 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_SHOW (needs: "Need(method='role', value='plugin_action_command_notification_show')")
2022-05-26 00:00:06,632 - octoprint.server - INFO - Added new permission from plugin action_command_notification: PLUGIN_ACTION_COMMAND_NOTIFICATION_CLEAR (needs: "Need(method='role', value='plugin_action_command_notification_clear')")
2022-05-26 00:00:06,633 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: "Need(method='role', value='plugin_action_command_prompt_interact')")
2022-05-26 00:00:06,634 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: "Need(method='role', value='plugin_announcements_read')")
2022-05-26 00:00:06,635 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: "Need(method='role', value='plugin_announcements_manage'), Need(method='role', value='plugin_announcements_read')")
2022-05-26 00:00:06,636 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: "Need(method='role', value='plugin_appkeys_admin')")
2022-05-26 00:00:06,636 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_GRANT (needs: "Need(method='role', value='plugin_appkeys_user')")
2022-05-26 00:00:06,637 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: "Need(method='role', value='plugin_backup_access')")
2022-05-26 00:00:06,638 - octoprint.server - INFO - Added new permission from plugin dashboard: PLUGIN_DASHBOARD_ADMIN (needs: "Need(method='role', value='plugin_dashboard_admin')")
2022-05-26 00:00:06,642 - octoprint.server - INFO - Added new permission from plugin firmware_check: PLUGIN_FIRMWARE_CHECK_DISPLAY (needs: "Need(method='role', value='plugin_firmware_check_display')")
2022-05-26 00:00:06,645 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: "Need(method='role', value='plugin_logging_manage')")
2022-05-26 00:00:06,648 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: "Need(method='role', value='plugin_pi_support_check')")
2022-05-26 00:00:06,650 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_LIST (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
2022-05-26 00:00:06,653 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: "Need(method='role', value='plugin_pluginmanager_manage')")
2022-05-26 00:00:06,655 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: "Need(method='role', value='plugin_pluginmanager_manage'), Need(method='role', value='plugin_pluginmanager_install')")
2022-05-26 00:00:06,658 - octoprint.server - INFO - Added new permission from plugin psucontrol: PLUGIN_PSUCONTROL_CONTROL (needs: "Need(method='role', value='plugin_psucontrol_admin')")
2022-05-26 00:00:06,661 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: "Need(method='role', value='plugin_softwareupdate_check')")
2022-05-26 00:00:06,663 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: "Need(method='role', value='plugin_softwareupdate_update')")
2022-05-26 00:00:06,665 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CONFIGURE (needs: "Need(method='role', value='plugin_softwareupdate_configure')")
2022-05-26 00:00:08,406 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2022-05-26 00:00:09,697 - octoprint.util.pip - INFO - Version of pip is 20.3.3
2022-05-26 00:00:09,731 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2022-05-26 00:00:09,731 - octoprint.util.pip - INFO - ==> pip ok -> yes
2022-05-26 00:00:10,092 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2022-05-26 00:00:10,129 - octoprint.plugins.softwareupdate - INFO - Loaded update log from disk
2022-05-26 00:00:10,631 - octoprint.plugin.core - INFO - Initialized 39 plugin implementation(s)
2022-05-26 00:00:10,948 - octoprint.plugin.core - INFO - 39 plugin(s) registered with the system:
| Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
| Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
| Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
| Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
| Bed Visualizer (1.1.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_bedlevelvisualizer
| BLTouch Plugin (0.3.4) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_BLTouch
| Camera Settings (0.4.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_CameraSettings
| Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
| Dashboard (1.19.8) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_dashboard
| Detailed Progress (0.2.7) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_detailedprogress
| Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
| DisplayLayerProgress Plugin (1.28.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_DisplayLayerProgress
| Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
| Event Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/eventmanager
| File Check (2021.2.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
| FileManager (0.1.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_filemanager
| Firmware Check (2021.10.11) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
| Fullscreen Plugin (0.0.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_fullscreen
| GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
| GPIO-Status (0.2.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_gpiostatus
| Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
| M73 Progress Plugin (0.2.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_m73progress
| OctoEverywhere! (1.6.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_octoeverywhere
| Pi Support Plugin (2022.3.28) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_pi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
| PortLister (0.1.10) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_portlister
| Printer Stats (3.1.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_stats
| PSU Control (1.0.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_psucontrol
| PSU Control - Tasmota (1.0.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_psucontrol_tasmota
| Resource Monitor (0.3.6) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_resource_monitor
| Simple Filament Change Buttons (1.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_simple_filament_change_buttons
| Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
| Themeify (1.2.2) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_themeify
| Thermal-Runaway (3.1.0) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_ThermalRunaway
| Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
| WS281x LED Status (0.8.1) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_ws281x_led_status
| Z Probe Offset (0.5) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_z_probe_offset
2022-05-26 00:00:11,018 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1000.0
| ram: 382574592
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| python:
| pip: 20.3.3
| version: 3.7.3
2022-05-26 00:00:11,054 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2022-05-26 00:00:11,056 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2022-05-26 00:00:11,059 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-manifest.json...
2022-05-26 00:00:12,484 - octoprint.server - INFO - Shutting down intermediary server...
2022-05-26 00:00:12,800 - octoprint.server - INFO - Intermediary server shut down
2022-05-26 00:00:12,808 - octoprint.events - INFO - Processing startup event, this is our first event
2022-05-26 00:00:12,808 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2022-05-26 00:00:12,816 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2022-05-26 00:00:12,825 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2022-05-26 00:00:12,893 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2022-05-26 00:00:12,961 - octoprint.server - INFO - Trying to connect to configured serial port None
2022-05-26 00:00:13,418 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2022-05-26 00:00:13,463 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2022-05-26 00:00:13,490 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2022-05-26 00:00:13,514 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2022-05-26 00:00:13,514 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2022-05-26 00:00:13,528 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2022-05-26 00:00:13,567 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-05-26 00:00:13,577 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-05-26 00:00:14,369 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._http._tcp.local.' for _http._tcp.local.
2022-05-26 00:00:15,221 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._octoprint._tcp.local.' for _octoprint._tcp.local.
2022-05-26 00:00:15,246 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2022-05-26 00:00:15,387 - octoprint.plugins.gpiostatus - INFO - Plugin ready
2022-05-26 00:00:15,387 - octoprint.plugins.octoeverywhere - INFO - OctoPrint port 5000
2022-05-26 00:00:15,588 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2022-05-26 00:00:15,600 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-05-26 00:00:16,820 - octoprint.plugins.octoeverywhere - INFO - OctoPingPong stats loaded from file.
2022-05-26 00:00:16,823 - octoprint.plugins.psucontrol - INFO - Registered plugin - psucontrol_tasmota
2022-05-26 00:00:16,897 - octoprint.plugins.octoeverywhere - INFO - IPV4 - starport:165.227.157.16 main:104.21.49.248
2022-05-26 00:00:16,935 - octoprint.plugins.octoeverywhere - INFO - Failed to resolve host ipv6 name [Errno -2] Name or service not known
2022-05-26 00:00:16,936 - octoprint.plugins.ws281x_led_status - INFO - Running OS config test (Log mode)
2022-05-26 00:00:16,942 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2022-05-26 00:00:17,029 - octoprint.plugins.ws281x_led_status - INFO - OS config test complete. Results:
| - adduser: True
| - spi_enabled: True
| - spi_buffer_increase: True
| - set_core_freq: True
| - set_core_freq_min: True
2022-05-26 00:00:17,224 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2022-05-26 00:00:17,610 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2022-05-26 00:00:17,632 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-05-26 00:00:18,625 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2022-05-26 00:00:18,626 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2022-05-26 00:00:18,626 - octoprint.util.pip - INFO - ==> pip ok -> yes
2022-05-26 00:00:18,711 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 8.5GB. That is considered sufficient for updating.
2022-05-26 00:00:18,712 - octoprint.plugins.softwareupdate - INFO - Not fetching check overlays, we are offline
2022-05-26 00:00:19,630 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2022-05-26 00:00:19,639 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 250000
2022-05-26 00:00:19,653 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-05-26 00:00:19,956 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-05-26 00:00:20,065 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2022-05-26 00:00:20,088 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Operational"
2022-05-26 00:00:20,151 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-05-26 00:00:20,400 - octoprint.plugins.stats - INFO - Printer Stats - on_event
2022-05-26 00:00:20,620 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 2.1.0.1 MRiscoC 422 BLTouch, based on bugfix-2.0.x (Apr 19 2022 23:52:28)"
2022-05-26 00:00:20,709 - octoprint.plugins.z_probe_offset - INFO - Printer_cap[eeprom]:1
2022-05-26 00:00:20,737 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2022-05-26 00:00:20,824 - octoprint.plugins.z_probe_offset - INFO - Printer_cap[z_probe]:1
2022-05-26 00:00:20,892 - octoprint.util.comm - INFO - Firmware states that it supports emergency GCODEs to be sent without waiting for an acknowledgement first
2022-05-26 00:00:21,332 - octoprint.plugins.ws281x_led_status - INFO - Switched lights, on: True
2022-05-26 00:00:21,374 - octoprint.plugins.z_probe_offset - INFO - Z probe offset is now -1.95
2022-05-26 00:00:22,542 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2022-05-26 00:00:23,221 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2022-05-26 00:00:23,229 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2022-05-26 00:00:23,235 - octoprint.util.pip - INFO - ==> pip ok -> yes
2022-05-26 00:00:23,742 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2022-05-26 00:00:23,824 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2022-05-26 00:00:23,828 - octoprint.plugins.dashboard - INFO - Dashboard started
2022-05-26 00:00:23,935 - octoprint.JsFrontendErrors(Dash) - INFO - Js Logger (Dash) started
2022-05-26 00:00:23,968 - octoprint.plugins.detailedprogress - INFO - OctoPrint-DetailedProgress loaded!
2022-05-26 00:00:23,998 - octoprint.plugins.octoeverywhere - INFO - After startup called. Starting worker thread.
2022-05-26 00:00:24,014 - octoprint.plugins.octoeverywhere - INFO - Main thread starting
2022-05-26 00:00:24,051 - octoprint.plugins.portlister - INFO - Port Lister () {}
2022-05-26 00:00:24,163 - octoprint.plugins.stats - INFO - Printer Stats
2022-05-26 00:00:24,221 - octoprint.plugins.themeify - INFO - Themeify initialized.
2022-05-26 00:00:25,554 - octoprint.plugins.ws281x_led_status - INFO - WS281x LED Status runner started
2022-05-26 00:00:25,888 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2022-05-26 00:00:26,445 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://octopi.local/', 'path': '/', 'query_string': 'l10n=de'}
2022-05-26 00:00:26,872 - octoprint.plugins.octoeverywhere - INFO - Frontend http port detected as 80, is https? False
2022-05-26 00:00:26,876 - octoprint.plugins.octoeverywhere - INFO - Attempting to talk to OctoEverywhere, server con wss://starport-v1.octoeverywhere.com/octoclientws[1]
2022-05-26 00:00:27,133 - octoprint.plugins.octoeverywhere - INFO - Connected To OctoEverywhere, server con wss://starport-v1.octoeverywhere.com/octoclientws[1]. Starting handshake...
2022-05-26 00:00:28,891 - octoprint.plugins.octoeverywhere - INFO - Handshake complete, server con wss://starport-v1.octoeverywhere.com/octoclientws[1], successfully connected to OctoEverywhere!
2022-05-26 00:00:36,122 - octoprint.server.util.flask - INFO - Passively logging in user Ronny from 127.0.0.1
2022-05-26 00:00:36,123 - octoprint.access.users - INFO - Logged in user: *****
2022-05-26 00:00:45,756 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-26 00:00:50,769 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-26 00:00:55,785 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-26 00:01:00,812 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-26 00:01:05,839 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-26 00:01:10,899 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-26 00:01:15,981 - octoprint.plugins.psucontrol_tasmota - ERROR - Unable to communicate with device. Check settings.
2022-05-26 00:01:18,603 - octoprint.server.preemptive_cache - INFO - ... done in 52.16s
2022-05-26 00:01:18,603 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://192.168.178.115/', 'path': '/', 'query_string': 'l10n=de'}
2022-05-26 00:01:18,805 - octoprint.plugins.octoeverywhere - INFO - Slipstream Cached [request:54.596, compression:0.166] [929347->139024 14.959%] /
2022-05-26 00:01:20,968 - octoprint.server.preemptive_cache - INFO - ... done in 2.37s
