Just upgraded to latest version. Camera works, I can't find in the UI where to download/delete timelapse images, it used to be in the menu. Tried searching for answers but only hit is that a new "plugin" feature is now available but no information as to what is now needed to restore this normal function.
Searched community and documentation
No, wouldn't think that would help?
N/A
Chrome/113.0.0.0 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1500.0
env.hardware.ram: 4025733120
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.2
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.9.0
printer.firmware: Marlin 2.0.7.2 (Jul 16 2022 14:09:12)
systeminfo.generated: 2023-05-28T16:44:23Z
systeminfo.generator: zipapi
I believe the issue is related to the new release and a change in the way the system works without documenting the changes to direct users to the steps/resources needed to achieve the same functionality prior to upgrade.
