**What is the problem?**I recently installed a Starlink network and have been unable to connect my octoprint with the wifi router. I am able to connect via a CenturyLink router and am able to connect phones, TVs and other devices to the Starlink router - I just can't make the connection from octoprint to the new system. Any suggestions?
What did you already try to solve it? I have edited the sd card with every address I can think of - caps, small letters, info on router label, etc.
One of the best ways to debug wifi connection issues is connecting a HDMI monitor to your Pi. This means you can run diagnostic commands if it doesn't show you the IP address when you plug it in.
You can scan for wifi networks using this command while plugged into a monitor sudo iwlist wlan0 scan. You should be able to use sudo raspi-config to set the network after you figure out the name.
