I use a Raspi 4 with the actual Octopi and OctoPrint version.
I want to connect a 5" display (HDMI) to use Octodash. If I connect the display it shows only a grey screen.
For the display I had to add at the end of the config.txt some lines.
Now the system tried to start, but stopped then. I could not reach it. It only runs without the additional lines.
Do I have to install Octodash before over the terminal?
I tried to connect the display to a raspi with the normal operating system and it works without any additional lines in the config.txt.
Could somebody give me some advices what I have to do for a running system?
I think I found my mistake, I have to connect the display to the 13*2 Pin Socket. But this is not possible for me because I use it for the relays and other things.
