Octoprint booted safe mode/concerned of octoprint failing on me again
Octoprint booted into safe mode. I am concerned because i had a lot of trouble with the login system as well as the reauthentication system so i dont want errors like system start incomplete showing up.
Nothing, before with the reauthentication issue, i switched to klipper because i was tired of the constant me getting kicked out of octoprint issue and not getting back in because the apis broken (thats what i think it was, it always gave me an 403 in the console leading to the api)
It ran in safe mode
Idk
octoprint-systeminfo-20250405220332.zip (16.2 KB)
Kobra 2, Raspi 4, Switched from an 32gb sd to an 4gb sd because i dont have another flying around and i think the old one was either corrupted or some plugin annoyed me.
Looking in the logs heres all the warnings i found:
-Tornado shows an 403 POST /api/login warning a bunch of times. That might be the cause of the login system not liking me.
-The sysinfo shows the reason for the safe mode boot is incomplete_startup
-Octoprint Logs show warning py with Falling back from lgpio: No module named lgpio
-Octoprint Logs show warning plugin simpleemergencystop is reffering to non existing css asset fontaswesome.all.min.css (believe this is just some visual element or font missing)
-There are a bunch of warnings about CRSF disabled which i beleive isnt the issue either
-There is a warning about Deprecation and Detected acess to deprecated settings path ['webcam', 'snapshot'], returned value is derived
Thats it. Ngl none of those issues seem that critical to me. Look over it please, i might have overlooked something fatal.
