Hello,
Since a short period of time I have an issue with installing ANY plugin on my Octoserver.
I run a RaspberryPi 3b. It gives me always the same errors:
2020-06-10 10:22:00,299 - octoprint.plugins.pluginmanager - INFO - Installing plugin from http s://github.com/christophschranz/OctoPrint-PrePrintService/archive/master.zip
2020-06-10 10:22:03,263 - octoprint.plugins.pluginmanager - ERROR - Installing the plugin from http s://github.com/christophschranz/OctoPrint-PrePrintService/archive/master.zip failed, could not parse output from pip. See plugin_pluginmanager_console.log for generated output
2020-06-10 10:22:18,683 - octoprint.plugins.pluginmanager - INFO - Installing plugin from http s://github.com/OllisGit/OctoPrint-PrintJobHistory/releases/latest/download/master.zip
2020-06-10 10:22:21,446 - octoprint.plugins.pluginmanager - ERROR - Installing the plugin from http s://github.com/OllisGit/OctoPrint-PrintJobHistory/releases/latest/download/master.zip failed, could not parse output from pip. See plugin_pluginmanager_console.log for generated output
I tried several random plugins on the web. All of them it gives the error that the file does not exist.
So I thought maybe it is a network issue but also that seems to be fine.
pi@octopi:~ $ ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=55 time=14.1 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=55 time=14.9 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=55 time=17.9 ms
64 bytes from 8.8.8.8: icmp_seq=4 ttl=55 time=24.5 ms
64 bytes from 8.8.8.8: icmp_seq=5 ttl=55 time=15.5 ms
^C
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 9ms
rtt min/avg/max/mdev = 14.136/17.398/24.530/3.786 ms
Does anyone have any idea what this problem might be?
The strange part is that it used to work fine and I'm not sure till when. Did not install any new plugins for several weeks so this error didn't occur to me yet. Updating plugins works fine also by the way.
There's spaces within all but one of your https domains. I take it you are copy-pasting the URLs? What happens if you install directly from the repository via the install button in the repo browser in OctoPrint's Plugin Manager?
I do not have any adblock or pihole or any other custom firewall applications running.
Also i placed spaces in the links because the website gave an error i wasn't allowed to share more than 5 links (new user) so i took most of them out.
If i install a .zip directory directly in octoprint i get the following:
Take a couple steps back. What exactly are you doing there? It looks like you are pasting the manual install line from the repository into the URL field of the plugin manager.
That won't work. Just the URL contained therein should. But you really don't need to manually copy paste stuff, right above the URL input field there's a huge repository browser which contains exactly the same plugins that are on plugins.octoprint.org.
Also please share the full logs, not just excerpts. You have us flying almost blind here
As @foosel said:
You have to use the URL when you manually install with the Plugin Manager, not the Command line:
2020-06-10 09:52:08,219 ! Hint: It looks like a path. File 'pip install "https://github.com/OllisGit/OctoPrint-PrintJobHistory/releases/latest/download/master.zip"' does not exist.
Like i said, a few weeks ago it still managed to work fine and I haven't changed anything.
Only different thing was that usually my Raspberry is always online and it has been 3 weeks powerless. After startup the problem occured
I'm pretty sure it currently has pip install "https://github.com/OllisGit/OctoPrint-PrintJobHistory/releases/latest/download/master.zip" in there, which you must have put there by accident.
