If printing and object output by fusion360 with a high detail level, my prusa original mk2.5 printer can stutter moving, especially on circles.
Printing directly from SD either via octoprint or on the printer physical controls the print works correctly. If I load the gcode to octroprint and try printing via usb I get this issue.
It seems to only happen on complex parts of the print, areas that have many short lines or commands that are quick to execute. So my theory is that the buffer on the prusa is emptying before it can be filled via octoprint.
My current solutions are either to use a lower quality output on fusion, but that's not a great fix, I would like to print in a good quality and also this isn't an option for downloaded stl's that I don't have the original design for. Or to load the gcode onto the sd card and print from there, but then I loose alot of the goodness of using octoprint.
OctoPrint 1.3.9 running on OctoPi 0.14.0
Original prusa mk2.5
Serial connection speed 115200
