On a freshly flashed Octopi 0.17.0 (I have tried 2 SD Cards, 2 different Pis (2B and 4B) and 2 different Wifi networks)
During the setup wizard I named my printer CR10 and put in it's print bed dimensions but it doesn't take. When I go to settings-->printer profile it shows the printer as default and generic rep-rap printer with the default 200 x 200 x 200 build area.
I find that I cannot update my printer profile. I can add a new printer profile but it will not register other than the default 200 x 200 x 200 build area. I also cannot set it to default. Eventually an error pop-up will appear "Could not update printer profile".
Tried different Pi, different SD card and wifi network.
Googled for similar issue reports. I haven't found one that's quite the same.
octoprint logs.zip (8.9 KB)
I'm using the latest version of OctoPrint straight from the website, no extra plugins. I've tried a new SD Card and have use a Pi 2B and 4B and get exactly the same result. I get this error straight after install. If anyone can figure out what's going on I'd sure appreciate it.
