Hi everyone,
I use a RPI 3B+ to print with a Palette 2S Pro and a Prusa MK3S
I had the good surprise today to find my Prusa MK3S in "pause" after about 3 hours of printing, the extruder waiting above the print and an octoprint server which did not answer any more. Nothing special on the Palette and MK3s screens, just the webpage that inform me to check the octoprint.log
searching in the log file "octoprint.log" I found this:
2020-09-29 17:05:14,569 - octoprint.server - CRITICAL - Now that is embarrassing... Something really really went wrong here. Please report this including the stacktrace below in OctoPrint's bugtracker. Thanks!
2020-09-29 17:05:14,572 - octoprint.server - ERROR - Stacktrace follows:
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/init.py", line 940, in run
ioloop.start()
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/ioloop.py", line 1048, in start
event_pairs = self._impl.poll(poll_timeout)
MemoryError
2020-09-29 17:05:14,587 - octoprint.server - INFO - Shutting down...
2020-09-29 17:05:14,701 - octoprint.server - INFO - Calling on_shutdown on plugins
2020-09-29 17:05:14,702 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2020-09-29 17:05:14,712 - octoprint.events - INFO - Event loop shut down
2020-09-29 17:05:14,744 - octoprint.plugins.palette2 - INFO - Shutdown
2020-09-29 17:05:14,746 - octoprint.plugins.palette2 - INFO - Disconnecting from Palette 2
2020-09-29 17:05:14,751 - octoprint.plugins.palette2 - INFO - Resetting threads
2020-09-29 17:05:16,590 - octoprint.plugins.palette2 - INFO - Resetting all values
2020-09-29 17:05:16,601 - octoprint.plugins.palette2 - INFO - Updating all UI variables
2020-09-29 17:05:16,669 - octoprint.plugins.palette2 - INFO - Paths: ['/dev/serial/by-id/usb-FTDI_FT230X_Basic_UART_DM02GTEG-if00-port0']
2020-09-29 17:05:16,702 - octoprint.plugins.palette2 - INFO - ADVANCED UPDATE UI
2020-09-29 17:05:16,752 - octoprint.server - INFO - Goodbye!
I don't know what to do next to investigate and that's why I'm asking for your opinion.
Thank you
Restart
update pip
update apt-get
update python to version 3
curl -L https://get.octoprint.org/py3/upgrade.py --output upgrade.py
python3 upgrade.py
Complete Logs
full log available here : https://1drv.ms/u/s!AjC2bJhplz3diuUH5oVOsgh-9nNUsg?e=dRlGfT
OctoPrint version : 1.4.2
OctoPi version : 0.17.0
