High ping to the router when octoprint is on. This translates to high internet ping. Seems to have started occurring when I set up Octofarm as well as one webcam per printer.
Turned off all octoprint instances (leaving octofarm on). This resolves the high ping to router. Shown with the logs below
When octoprint is on (all 5 printers)
Pinging 192.168.1.1 with 32 bytes of data
Reply from 192.168.1.1: bytes=32 time=15ms TTL=64
Reply from 192.168.1.1: bytes=32 time=98ms TTL=64
Reply from 192.168.1.1: bytes=32 time=130ms TTL=64
Reply from 192.168.1.1: bytes=32 time=78ms TTL=64
Reply from 192.168.1.1: bytes=32 time=112ms TTL=64
Reply from 192.168.1.1: bytes=32 time=193ms TTL=64
Reply from 192.168.1.1: bytes=32 time=188ms TTL=64
Reply from 192.168.1.1: bytes=32 time=9ms TTL=64
Reply from 192.168.1.1: bytes=32 time=34ms TTL=64
Reply from 192.168.1.1: bytes=32 time=29ms TTL=64
Reply from 192.168.1.1: bytes=32 time=241ms TTL=64
Reply from 192.168.1.1: bytes=32 time=11ms TTL=64
Reply from 192.168.1.1: bytes=32 time=37ms TTL=64
Reply from 192.168.1.1: bytes=32 time=91ms TTL=64
Reply from 192.168.1.1: bytes=32 time=280ms TTL=64
When octoprint is off (Again all 5 printers)
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=6ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=13ms TTL=64
CM500 modem
R7000 nighthawk router
