Raspberry Pi Camera Module 3 - Wide
I noticed a lot of latency and lagging on my home network recently and begin to look into things consuming large amounts of bandwidth. I found that OctoPrint is on average consuming anywhere from 30-60Mb/s in uploaded data to somewhere. In some cases this number jumps as high as 200-300Mb/s. Even if the stream from the camera were 100% RAW I wouldn't believe it would take that much data. Trying to determine what's going on.
Haven't done anything to solve yet, this is information gathering to see if anyone else is experiencing this.
NetHogs version 0.8.5-2+b1
PID USER PROGRAM DEV SENT RECEIVED
463 pi /home/pi/oprint/bin/python lo 0.917 0.000 KB/sec
875 haproxy /usr/sbin/haproxy lo 2.578 0.000 KB/sec
604 root ./mjpg_streamer lo 3103.294 0.000 KB/sec
? root unknown TCP 0.000 0.000 KB/sec
TOTAL 3106.789 0.000 KB/sec
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: libcamera
usb options: -r 640x480 -f 10
raspi options: -fps 10
libcamera options: -r FHD -f 30
http options: -w ./www-octopi -n
Explicitly set USB device:
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
/dev/video19
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/video31
config file='/boot/octopi.txt':Starting MJPG-streamer with video device: libcamera
<13>Jan 21 03:00:00 root: Starting Libcamera camera
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n -i input_libcamera.so -r FHD -f 30
MJPG Streamer Version: git rev: 290776e2d59ecf4589ffe15800e1ccfe17dc07e7
i: Desired Resolution: 1920 x 1280
[0:00:09.857393751] [604] INFO Camera camera_manager.cpp:299 libcamera v0.0.0+4135-f8a5e271
[0:00:09.978045362] [639] INFO RPI raspberrypi.cpp:1425 Registered camera /base/soc/i2c0mux/i2c@1/imx708@1a to Unicam device /dev/media3 and ISP device /dev/media0
o: HTTP Listen Address..: (null)
Configuring still capture...
Still capture setup complete
[0:00:09.985407659] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 1920x1280-BGR888
[0:00:09.986317177] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
Done bringing up all configured video devices
[0:03:27.854648544] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 4608x2592-BGR888
[0:03:27.855540427] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 4608x2592-SBGGR10_1X10 - Selected unicam format: 4608x2592-pBAA
[0:03:28.522906204] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 1920x1280-BGR888
[0:03:28.524185788] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
[0:03:42.337094811] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 4608x2592-BGR888
[0:03:42.337955010] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 4608x2592-SBGGR10_1X10 - Selected unicam format: 4608x2592-pBAA
[0:03:43.017868654] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 1920x1280-BGR888
[0:03:43.027037453] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
[0:05:04.883339263] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 4608x2592-BGR888
[0:05:04.884398858] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 4608x2592-SBGGR10_1X10 - Selected unicam format: 4608x2592-pBAA
[0:05:05.551031100] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 1920x1280-BGR888
[0:05:05.574723577] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
[0:11:35.535303368] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 4608x2592-BGR888
[0:11:35.538669440] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 4608x2592-SBGGR10_1X10 - Selected unicam format: 4608x2592-pBAA
[0:11:36.207892339] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 1920x1280-BGR888
[0:11:36.209280775] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
[0:11:50.084843297] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 4608x2592-BGR888
[0:11:50.087735427] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 4608x2592-SBGGR10_1X10 - Selected unicam format: 4608x2592-pBAA
[0:11:50.781799457] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 1920x1280-BGR888
[0:11:50.782473508] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
[0:13:26.838921929] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 4608x2592-BGR888
[0:13:26.839924849] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 4608x2592-SBGGR10_1X10 - Selected unicam format: 4608x2592-pBAA
[0:13:27.507400491] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 1920x1280-BGR888
[0:13:27.519784916] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
[0:20:50.287412054] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 4608x2592-BGR888
[0:20:50.288345091] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 4608x2592-SBGGR10_1X10 - Selected unicam format: 4608x2592-pBAA
[0:20:50.947734684] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 1920x1280-BGR888
[0:20:50.948553296] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
[0:21:04.852900429] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 4608x2592-BGR888
[0:21:04.853822133] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 4608x2592-SBGGR10_1X10 - Selected unicam format: 4608x2592-pBAA
[0:21:05.520749061] [649] INFO Camera camera.cpp:1026 configuring streams: (0) 1920x1280-BGR888
[0:21:05.531682362] [639] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx708@1a - Selected sensor format: 2304x1296-SBGGR10_1X10 - Selected unicam format: 2304x1296-pBAA
OctoPrint v1.8.6
Raspberry Pi 4B
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 3926347776
env.os.bits: 64
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 1.0.0
env.plugins.pi_support.throttle_check_enabled: true
env.plugins.pi_support.throttle_check_functional: true
env.python.pip: 22.3
env.python.version: 3.9.2
env.python.virtualenv: true
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: false
octoprint.version: 1.8.6
printer.firmware: 2.0.8.2 (Jul 6 2022 19:18:56)
systeminfo.generated: 2023-01-21T03:38:22Z
