I can't get a button to send a script to the pi
I tried using command and also script
command: sends the script to the printer!
script: seems to do nothing
terminal output if I use command:
Send: ~/scripts/SetLeds 1 1 1
Recv: echo:Unknown command: "~/scripts/SetLeds 1 1 1"
Recv: ok
octoprint 1.4.0
octopi 0.17.0
Creality Ender-3
Raspberry pi 3B
yaml excerpt:
controls:
- children:
- name: blue LED script
script: ~/scripts/SetLeds 0 0 1
- command: ~/scripts/SetLeds 0 0 1
name: blue LED command
buttons appear on the control page as expected
click the one marked "blue LED script"
nothing happens
click the one marked "blue LED command"
script is sent to the printer
(I guess that's to be expected)
but where does the "script" go?!?
thanks
