Brand new to Octoprint so please accept my excuses in advance. I have a Creality CR-10S Pro which I have been using for big, fast prints for 6 months now. I need Octoprint because I'm tired of the SD card shuffle but also because I want some security when I'm away from the printer. Here's my issue:
Install and setup of Octopi on a brand new 'official' pi 3b (with mains adaptor), went fine. Connecting to my printer ditto. I had some problems with temperature parsing but thanks to this forum, found the solution and added the plugin. All is good except that if I pause a print, Octoprint crashes to the point that I cannot reboot it other than by physically unplugging the pi.
My printer firmware is up to date, (1.60.7 stock), and I am running Octoprint 1.3.11 on Octopi 0.16.0
No GCode scripts... (I'm a Newbie!). If I did have a pause script, I presume I could park the nozzle in a safe place, cool down the head and bed, turn off the fans etc. Then run a resume script to fire it all up again and pick up the print where it left off?
FYI, I did run with OctoPrint Anywhere off but with the same result. Except that I was too fast to blame "Pause". The culprit is "Cancel", which is when the crash happens.
OK, I get it. There's a place to add your custom pause / resume scripts which are run when I hit the console buttons. I guess there are some standard ones which I didn't get?
Another issue is that my console does not offer 'Resume' if cancel is enabled. I will fool around with some scripts and see if that changes anything. If anyone has some standard, basic scripts I'd be grateful.
By the way: you may shut off the hotend heating, but never do it with the heatbed, because the adhesion will fail and the model gets lose and it will be impossible to continue a proper print.
