I'm using Octopi and Cura, and recently, the bed temp has been being set to 110 degrees, when it's only supposed to be at 60. What did you already try to solve it?
I messed with a ton of settings, but couldn't find the fix Logs (octoprint.log, serial.log or output on terminal tab, ...)
Recv: ok T:72 /185 B:70 /110 @:128 B@:128 I think that has something to do with it
Not really sure what to tell you since the gcode looks good (enough). I do see some redundancy like the two sets of G92 E0, for example.
Make sure that you haven't set some offset in the OctoPrint -> Control interface.
This suggests that the target for the extruder has been set to 185 but unfortunately it thinks that something has set the bed to 110. Check the printer profile in OctoPrint and also the filament default profiles since it's possible that you told it to preheat for something and it's trying to use those settings.
