hi,
last print i shutdown my raspberry pi with the autoshutdown plugin.
| Send: N13197 G0 X61.009 Y125.744*26
| Recv: ok
| Send: N13198 G0 X60.943 Y125.818*21
| Recv: ok
| Send: N13199 M204 S3000*86
| Recv: ok
| Send: N13200 M205 X20 Y20*37
| Recv: ok
| Send: N13201 G1 F1800 X60.739 Y125.596 E1036.00507*13
| Recv: Setting Print and Travel Acceleration: 3000.00
| Recv: ok
| Recv: ok
| Send: N13202 G1 X60.637 Y125.405 E1036.01191*111
| Send: N13203 G1 X60.6 Y125.196 E1036.01861*99
| Recv: ok
| Send: N13204 G1 X60.6 Y106.799 E1036.59991*111
| Recv: ok
| Send: N13205 G1 X108.201 Y106.799 E1038.10396*90
| Recv: Error:checksum mismatch, Last Line: 13202
| Recv: Resend: 13203
2018-11-01 18:22:18,762 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-11-01 18:37:18,764 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-11-01 18:52:18,768 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-11-01 18:56:02,717 - octoprint.util.comm - INFO - Finished in 3686.766 s.
2018-11-01 18:56:02,719 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2018-11-01 18:56:02,745 - octoprint.plugins.detailedprogress - INFO - Printing stopped. Detailed progress stopped.
2018-11-01 18:56:02,835 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2018-11-01 18:56:07,762 - octoprint.plugins.automaticshutdown - INFO - Waiting for 1 timelapse(s) to finish rendering before starting shutdown timer...
2018-11-01 18:56:12,785 - octoprint.plugins.automaticshutdown - INFO - Starting abort shutdown timer.
2018-11-01 18:56:42,802 - octoprint.plugins.automaticshutdown - INFO - Shutting down system with command: sudo shutdown -h now
2018-11-01 18:56:43,232 - octoprint.server - INFO - Shutting down...
2018-11-01 18:56:43,882 - octoprint.plugins.HeaterTimeout - INFO - Shutting down...
2018-11-01 18:56:43,885 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2018-11-01 18:56:43,902 - octoprint.events - INFO - Event loop shut down
2018-11-01 18:56:45,042 - octoprint.server - INFO - Goodbye!
if i want to start by hand this happend
pi@octopi:~/oprint/local/lib/python2.7/site-packages $ octoprint serve
File "/home/pi/oprint/bin/octoprint", line 9, in <module>
load_entry_point('OctoPrint==1.3.9', 'console_scripts', 'octoprint')()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/__init__.py", line 598, in main
from octoprint.cli import octo
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/__init__.py", line 137, in <module>
from .client import client_commands
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/client.py", line 10, in <module>
import octoprint_client
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_client/__init__.py", line 8, in <module>
import requests
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests-2.18.4-py2.7.egg/requests/__init__.py", line 97, in <module>
from . import utils
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests-2.18.4-py2.7.egg/requests/utils.py", line 24, in <module>
from . import certs
File "/home/pi/oprint/local/lib/python2.7/site-packages/requests-2.18.4-py2.7.egg/requests/certs.py", line 15, in <module>
from certifi import where
ImportError: No module named certifi
and the installed plugins
pi@octopi:~/oprint/bin $ cat ~/.octoprint/logs/octoprint.log |grep "|" | grep "= /home/pi/" | sort | uniq | sed 's|\|||g' |grep -v "bundled"
Action Commands (0.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_actioncommands
Automatic Shutdown (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_automaticshutdown
Detailed Progress Plugin (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_detailedprogress
EEPROM Marlin Editor Plugin (1.2.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_eeprom_marlin
Fan Speed Control (0.1.8) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_fanspeedslider
FileManager (0.1.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filemanager
Firmware Updater (1.0.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmwareupdater
GcodeEditor (0.2.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_GcodeEditor
HeaterTimeout (0.0.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_HeaterTimeout
MQTT (0.7.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_mqtt
Preheat Button (0.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_preheat
Print History Plugin (1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_printhistory
Slicer (1.4.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_slicer
STL Viewer (0.4.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_stlviewer
wich version from octoprint i dont know. but not so old.
i did update an upgrade my raspi and also do some reboots. but octoprint wont start and that without any log`s
some reboots later .... it will be work ... OMG
