Octoprint did not start in Proxmox / Ubuntu 24.04 VM
Octoprint doesn't start.
First try wiht Helper script via:
Then tried to reinstall in Debian 12 / Ubuntu 22.04 / 24.04 VM (whith octoprint_deploy script).
Since the error occurs in all tested Linux versions – which I find strange – I will continue to analyze the error in Ubuntu 24.04 LTS with all current updates.
Yes. Result:
2025-04-18 15:25:38,984 - octoprint.startup - INFO - ******************************************************************************
2025-04-18 15:25:38,985 - octoprint.startup - INFO - Starting OctoPrint 1.10.3
2025-04-18 15:25:38,985 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2025-04-18 15:25:38,985 - octoprint.startup - INFO - Reason for safe mode: problem during last startup
2025-04-18 15:25:38,986 - octoprint.startup - INFO - ******************************************************************************
2025-04-18 15:25:39,209 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2025-04-18 15:25:39,229 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2025-04-18 15:25:39,229 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2025-04-18 15:25:39,229 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2025-04-18 15:25:39,236 - octoprint.startup - INFO - Blacklist processing done, adding 3 blacklisted plugin versions: roomtemp (any), GcodeEditor (>=0.1.1,<=0.2.8), gcodeleveling (>=0.1.0,<=0.1.1)
2025-04-18 15:25:39,242 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/OctoPrint/lib/python3.12/site-packages/octoprint/plugins, /home/pi/.prusamk4s/plugins and installed plugin packages...
2025-04-18 15:25:40,735 - octoprint.plugin.core - INFO - Plugin Pi Support Plugin (2023.10.10) did not pass check, not loading.
2025-04-18 15:25:40,777 - octoprint.plugin.core - INFO - Found 19 plugin(s) providing 19 mixin implementations, 39 hook handlers
2025-04-18 15:25:40,810 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2025-04-18 15:25:40,897 - octoprint.cli.server - ERROR - Uncaught exception
File "/home/pi/OctoPrint/bin/octoprint", line 8, in
sys.exit(main())
File "/home/pi/OctoPrint/lib/python3.12/site-packages/octoprint/init.py", line 1008, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/OctoPrint/lib/python3.12/site-packages/click/core.py", line 1161, in call
return self.main(*args, **kwargs)
File "/home/pi/OctoPrint/lib/python3.12/site-packages/click/core.py", line 1082, in main
rv = self.invoke(ctx)
File "/home/pi/OctoPrint/lib/python3.12/site-packages/click/core.py", line 1697, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/pi/OctoPrint/lib/python3.12/site-packages/click/core.py", line 1443, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/OctoPrint/lib/python3.12/site-packages/click/core.py", line 788, in invoke
return __callback(*args, **kwargs)
File "/home/pi/OctoPrint/lib/python3.12/site-packages/click/decorators.py", line 33, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/OctoPrint/lib/python3.12/site-packages/octoprint/cli/server.py", line 317, in serve_command
run_server(
File "/home/pi/OctoPrint/lib/python3.12/site-packages/octoprint/cli/server.py", line 163, in run_server
octoprint_server.run()
File "/home/pi/OctoPrint/lib/python3.12/site-packages/octoprint/server/init.py", line 389, in run
self._setup_app(app)
File "/home/pi/OctoPrint/lib/python3.12/site-packages/octoprint/server/init.py", line 1577, in _setup_app
limiter = Limiter(
File "/home/pi/OctoPrint/lib/python3.12/site-packages/flask_limiter/extension.py", line 280, in init
self.init_app(app)
File "/home/pi/OctoPrint/lib/python3.12/site-packages/flask_limiter/extension.py", line 342, in init_app
raise ConfigurationError(
limits.errors.ConfigurationError: Invalid rate limiting strategy fixed-window-elastic-expiry
No.
Sorry, no system information available as Octoprint won't start...
Proxmox 8.4.
Browser: brave / firefox ESR / Chromium
OS: Debian 12 / Ubuntu 22.04 / 24.04 VM
Kernel: 6.8.0-57-generic
Python 3.12.3
Latest Octoprint via octoprint_deploy 1.0.11
Any hints?
Best regards,
Thomas
See https://github.com/OctoPrint/OctoPrint/issues/5138
You make my day. Sometimes I just have tomatoes on my eyes...
Thanks for the tip, octoprint runs well now.
/home/pi/OctoPrint/bin/python3 -m venv /home/pi/OctoPrint/bin/
/home/pi/OctoPrint/bin/pip install limits==4.7.2
Best regards,
Thomas
This will also be fixed in OctoPrint 1.11.0 when it's rolled out next week.
The deploy script now installs the correct version:
Installing collected packages: limits
  Attempting uninstall: limits
    Found existing installation: limits 5.0.0
    Uninstalling limits-5.0.0:
      Successfully uninstalled limits-5.0.0
Successfully installed limits-4.7.2
OctoPrint apppears to have been installed successfully
HTH,
Thomas
