Octoprint dies after print job finished
After a print job is finished octoprint dies
power off and on
**octoprint 1.4.0, Creality Ender 3, Filament Sensor NG (1.0.2), I have 2 identical setups. One is fine the other not so.. Only real difference is that the failing one was installed from a later version of octopi **)
Hello @Ricky_El-Qasem!
Could you please share the logs you have been asked for?
Sorry wrong logs..
Logs are too big to upload so here is a dropbox link
Some where around 10:26am today is when the job finishes. I then try to access the UI and I get some error telling me to SSH and trying to restart the octoprint service.
Ok.
So the print started:
2020-03-10 17:42:47,509 - Changing monitoring state from "Operational" to "Starting"
And ended:
2020-03-11 10:26:31,536 - Changing monitoring state from "Finishing" to "Operational"
In the octoprint.log the end appears as:
2020-03-11 10:26:31,396 - octoprint.util.comm - INFO - Finished in 60223.888 s.
2020-03-11 10:26:31,400 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2020-03-11 10:26:31,405 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CE3_ZXuitape_v1.5.7.gcode
2020-03-11 10:26:31,410 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/CE3_ZXuitape_v1.5.7.gcode
2020-03-11 10:26:31,458 - octoprint.printer.standard.job - INFO - Print job done - origin: local, path: CE3_ZXuitape_v1.5.7.gcode, owner: admin
2020-03-11 10:26:31,476 - octoprint.plugins.filamentsensorng - INFO - PrintDone: Disabling filament sensor.
2020-03-11 10:26:31,537 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
this is the normal way a print ends.
After about 50 minutes this the OctoPrint is restarted again.
Between these is nothing.
What plugins are installed and have you already tried in safemode?
Only 2 extra plugins: Filament Sensor NG (1.0.2) and Sidebar Webcam.. After next print job I will try disable them and test. However its the same plugins I have on my other octopi and that works well.
Screenshot and logs before and after disabling the pluguns. My money is on the filament plugin as enabled it again later and it octo died again.
logs-plugins-disabled.zip (431.7 KB)
logs plugin enabled > https://www.dropbox.com/s/h359ytwmo7vf7u0/log-plugins-enabled.zip?dl=0
