2019-04-11 11:40:21,556 - octoprint.startup - INFO - ******************************************************************************
2019-04-11 11:40:21,568 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-04-11 11:40:21,572 - octoprint.startup - INFO - ******************************************************************************
2019-04-11 11:40:30,334 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-04-11 11:40:44,048 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-04-11 11:40:44,656 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-04-11 11:40:45,177 - octoprint.server - INFO - Intermediary server started
2019-04-11 11:40:45,190 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-04-11 11:40:49,989 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-04-11 11:40:50,005 - octoprint.printer.profile - ERROR - Profile _default does not exist, creating _default again and setting it as default
2019-04-11 11:40:51,063 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-04-11 11:40:51,076 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-04-11 11:40:56,058 - octoprint.util.pip - ERROR - Error while discovering pip command
  File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/pip.py", line 148, in trigger_refresh
  File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/pip.py", line 181, in _setup_pip
  File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/pip.py", line 435, in _get_pip_command
  File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/pip.py", line 254, in autodetect_pip
  File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/fixes.py", line 24, in decorated_function
  File "/home/pi/oprint/local/lib/python2.7/site-packages/sarge/__init__.py", line 1462, in run
  File "/home/pi/oprint/local/lib/python2.7/site-packages/sarge/__init__.py", line 1071, in run
  File "/home/pi/oprint/local/lib/python2.7/site-packages/sarge/__init__.py", line 1187, in run_node
  File "/home/pi/oprint/local/lib/python2.7/site-packages/sarge/__init__.py", line 1333, in run_command_node
  File "/home/pi/oprint/local/lib/python2.7/site-packages/sarge/__init__.py", line 655, in run
  File "/usr/lib/python2.7/subprocess.py", line 390, in __init__
  File "/home/pi/oprint/local/lib/python2.7/site-packages/sarge/__init__.py", line 567, in _execute_child
  File "/usr/lib/python2.7/subprocess.py", line 1023, in _execute_child
  File "/usr/lib/python2.7/pickle.py", line 1388, in loads
  File "/usr/lib/python2.7/pickle.py", line 864, in load
  File "/usr/lib/python2.7/pickle.py", line 977, in load_string
  File "/home/pi/oprint/lib/python2.7/encodings/__init__.py", line 100, in search_function
  File "/home/pi/oprint/lib/python2.7/encodings/string_escape.py", line 1
SyntaxError: Non-ASCII character '\xf6' in file /home/pi/oprint/lib/python2.7/encodings/string_escape.py on line 1, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
2019-04-11 11:40:56,135 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-04-11 11:40:56,960 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
|  Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
|  Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements
|  Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking
|  Application Keys Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/appkeys
|  Backup & Restore (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/backup
|  Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/corewizard
|  CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
|  Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/discovery
|  Force Login (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/forcelogin
|  Logging (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging
|  Pi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pi_support
|  Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
|  Printer Safety Check (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
|  Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
|  Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2019-04-11 11:40:57,094 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
|  hardware:
|    cores: 1
|    freq: 700.0
|    ram: 388001792
|  os:
|    platform: linux2
|  plugins:
|    pi_support:
|      model: Raspberry Pi Model B Rev 2
|      octopi_version: tnuvntN
|  python:
|    pip: 19.0.1
|    version: 2.7.13
|    virtualenv: /home/pi/oprint
2019-04-11 11:40:57,147 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-04-11 11:40:57,157 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-04-11 11:40:59,369 - octoprint.server - INFO - Shutting down intermediary server...
2019-04-11 11:40:59,824 - octoprint.server - INFO - Intermediary server shut down
2019-04-11 11:40:59,841 - octoprint.events - INFO - Processing startup event, this is our first event
2019-04-11 11:40:59,853 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-04-11 11:40:59,876 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-04-11 11:40:59,898 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-04-11 11:41:00,012 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-04-11 11:41:00,096 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-04-11 11:41:00,121 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-04-11 11:41:00,307 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-04-11 11:41:01,908 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2019-04-11 11:41:03,692 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 3.1s
2019-04-11 11:41:11,103 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 1.2s
2019-04-11 11:41:11,956 - octoprint.util.pip - ERROR - Error while discovering pip command
2019-04-11 11:41:12,083 - octoprint.plugin - ERROR - Error while calling plugin softwareupdate
  File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/__init__.py", line 230, in call_plugin
    except Exception as exc:
  File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 102, in on_after_startup
    self._check_environment()
  File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/__init__.py", line 188, in _check_environment
    and get_comparable_version(versions["pip"]) >= get_comparable_version(MINIMUM_PIP)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/version.py", line 121, in get_comparable_version
    if "-" in version_string:
TypeError: argument of type 'NoneType' is not iterable
2019-04-11 11:41:13,772 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.79s
2019-04-11 11:41:14,068 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2019-04-11 11:41:15,004 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.51s
2019-04-11 11:41:16,446 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.5s
2019-04-11 11:55:44,676 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-04-11 11:57:58,866 - octoprint.server - INFO - Shutting down...
2019-04-11 11:57:58,968 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2019-04-11 11:57:59,037 - octoprint.events - INFO - Event loop shut down
2019-04-11 11:57:59,277 - octoprint.server - INFO - Goodbye!
Sorry, took me a while to figure out how to select all the text and copy it
