I hadn't printed for a week. When I went to print something, my Octoprint server had disappeared.
I unplugged it, waited 30 seconds, and plugged it back in
Running what in "safe mode"? I can't even see the RasPi that hosts it.
I don't know the version, because the RasPi has disappeared. I am using a Prusa 3 single filament, using Chrome as my browser, Windows 10. It was working a week ago, and it is not working now. I have no idea what to do next to see what has gone wrong (the person who set it up for me is not able to help for reasons beyond both our control).
I connected an HDMI monitor to the RasPi. I had to modify config.txt to do it. I put the card with the modified config.txt in, plugged the RasPi in, nothing. Dead. No output on screen. So I swapped RasPis. Nothing. Dead. A friend suggested I re-flash the SD card. I tried to do so. The imager did not give me the promised option of setting the SSID/password, so I'm stuck.
EDIT I used NotePad++ to search for ssid in all files. I found it in D:\octopi-wpa-supplicant.txt. I uncommented the WPA2 option (since that's what I use), typed in my SSID and password, and uncommented the US line. I put the updated card in the RasPi. Nothing. I did not enable the HDMI connection. I will try that next.
