Octoprint disconnects intermittently from Ender 3 v2
Octoprint on Raspberry Pi 3 intermittently disconnects from Ender 3 v2
My issue is that my RPi3 will intermittently disconnect from my Ender 3 v2. It can happen at shorter and longer intervals of time. It happens when I print and when I'm at idle. I have reloaded Octoprint & OS several times. Tried it also on a brand new RPi3. Tried 3 different USB cables all with the tape mod. Tried two different Ender 3 v2 firmware. The printer is the only thing connected to the USB ports on the RPi3.
NO
octoprint-systeminfo-20220319104229.zip (137.7 KB)
octoprint (3).log (19.4 KB)
Creality printers are 1) very susceptible to EMI interference and 2) generators of EMI. This is not a good combination and requires careful shielding and routing of all cables. USB cables need to be short, shielded, and have ferrite beads. Cables connecting the electronics inside the printer may need to be rerouted. Sometimes something as simple as moving the RPi from one side of the printer to the other will help.
Search this forum for EMI and you will find numerous topics with multiple ways this issue has been addressed.
