After agree to update to 1.5.0 the octoprint service does not start any more.
message on web server is :
"The OctoPrint server is currently not running"
i performed some reboot, but still not working
tried manualy (as pi user):
sudo service octoprint restart without success
it does not start in safe mode too (modified config.yaml to test safe mode)
Complete Logs
from log :
2020-12-01 17:24:55,003 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 900.0
| ram: 917020672
| os:
| bits: 32
| platform: linux2
| plugins:
| pi_support:
| model: Raspberry Pi 2 Model B Rev 1.1
| octopi_version: 0.17.0
| throttle_state: '0x0'
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
When loggin with user pi, i've git this message :
File "", line 1, in
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/init.py", line 6, in
import logging as log
File "/usr/lib/python2.7/logging/init.py", line 26, in
import sys, os, time, cStringIO, traceback, warnings, weakref, collections
EOFError: EOF read where object expected
Access OctoPrint from a web browser on your network by navigating to any of:
So, any clues ?
Thanks for help.
