rpi camera v1.3 (that is the silkscreen on board but I believe camera module is v2)
Although I can stream using raspivid piped to vlc video from camera to http://<rpi_address>:port and retrieve the stream through vlc in another computer attached to the same local network, plugging this address to octoprint (which is running at the same rpi as standalone server (not octopi), does seem to produce any results on octoprint web interface
the command I am running on pi is
raspivid -o --t -0 -w 1920 -h 1080 -fps 30 -b 1000000 | cvlc -vvv stream:///dev/stdin --sout '#standard{access=http,mux=ts,dst=<rpi_address>:<port_name>}' :demux=h264
where <rpi_address> is local ip address and port is port number.
I also tried to reduce resolution and fps, or even not define them at all applying that way the default ones which I think are minimal. Also I tried to omit bitrate (-b option)
network is not problem here, I have test it that one machine has access to the other on specific port
tried to put a name on a stream like http://<rpi_address>:<port_name>/x and plug this to both ends (rpi command and octoprint) without sucess
octoprint-systeminfo-20220524224917.zip (12.9 KB)
Octoprint version is 8.1, I am running it on raspbian
